Your basket is empty
Seagate 1TB Constellation ES.3 7200RPM SAS-2 3.5" Hard Drive
Quicklinx: 9FKZWS00 Mfr#: ST1000NM0023
Seagate Constellation ES.3 ST1000NM0023 - hard drive - 1 TB - SAS 6Gb/s
Hard drive - internal
1 TB
Encryption Algorithm
256-bit AES
3.5" x 1/3H
SAS 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Enhanced Error Correction Code, Ramp Load, dual processor, PowerChoice, Protection Information (PI)
101.85 mm x 147 mm x 26.1 mm
605 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
1 TB
256-bit AES
3.5" x 1/3H
SAS 6Gb/s
Buffer Size
128 MB
101.85 mm
147 mm
26.1 mm
605 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
175 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,400,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
3.5" x 1/3H
Limited warranty - 5 years
5 °C
60 °C
Vibration Tolerance
0.25 g @ 5-500 Hz (non-operating)
