Your basket is empty
Seagate 1TB Constellation 7200rpm SAS-2 64MB ES 7200.2 Hard Drive
Quicklinx: 8FR1WS00 Mfr#: ST91000640SS
The Seagate Constellation.2 drive is the only 2.5-inch enterprise-class hard drive delivering enterprise reliability at the industry's lowest power consumption for storage-hungry nearline applications. Self-Encrypting Drive (SED) and FIPS 140-2 Validated SED security options are available to help you protect your data.
Seagate Constellation.2 ST91000640SS - hard drive - 1 TB - SAS 6Gb/s
Hard drive - internal
1 TB
2.5"
SAS 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Idle Read After Write (IRAW), Background Media Scan (BMS), Perpendicular Magnetic Recording (PMR), PowerChoice, S.M.A.R.T.
7 cm x 10.1 cm x 1.5 cm
200 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
1 TB
2.5"
SAS 6Gb/s
Buffer Size
64 MB
7 cm
10.1 cm
1.5 cm
200 g
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
8.5 ms (average)
Track-to-Track Seek Time
0.7 ms
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,400,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5"
Limited warranty - 5 years
5 °C
60 °C
5 - 95%
Shock Tolerance
70 g @ 2ms (operating) / 400 g @ 2ms (non-operating)
Vibration Tolerance
0.5 g @ 5-500 Hz (operating) / 3 g @ 5-500 Hz (non-operating)
