Seagate 12TB IronWolf Pro 3.5" SATA 6GB/s 7200RPM Hard Drive
Quicklinx: D9XLWS00 Mfr#: ST12000NE0007
Select:
For everything NAS, there's IronWolf and IronWolf Pro. Always on and always working, IronWolf is enhanced with AgileArray technology for optimal reliability and system agility. Multi-user technology and extreme workload rates allow IronWolf to perform and scale up with your enterprise.
IronWolf Health Management is designed to operate on compatible NAS systems such as Synology and ASUSTOR. Populated with supported IronWolf or IronWolf Pro HDDs It improves the overall system reliability by displaying actionable prevention, intervention or recovery options for the user.
First in its class, IronWolf drives are equipped with RV sensors on high capacity drives to maintain performance in multi-bay NAS enclosures. RV sensors on IronWolf Pro come standard, helping business and creative pros to have consistent performance for years to come.
  • Tough, ready, scalable
  • Actively protect your data with IronWolf health management in popular and enabled NAS
  • Multi-bay and NAS-ready with built-in RV sensor
  • Do more with multi-user optimization
    Do more with your NAS with multi-user optimization. Enabling user workloads on IronWolf and with IronWolf Pro, multiple users can confidently upload and download data to a NAS server. Whether you're a creative pro or a small business, IronWolf is on your side.
  • Be creative anywhere with IronWolf and your NAS
    Extensible and reliable storage helps keep you and your creative business on schedule. IronWolf and IronWolf Pro are great companions for your NAS for remote access, backups and file sharing from anywhere, making sharing ideas easy. For growing agencies and the need for more storage, IronWolf and IronWolf Pro are built to address NAS scalability challenges.
  • Grow your business NAS
    A thriving small business needs storage that can thrive with it. IronWolf is optimized for NAS in multi-RAID environments that not only handle the vibration, but also the high user workload rate in a high data traffic network.
  • Dominate the media
    Build your home NAS media empire with IronWolf HDDs. IronWolf and IronWolf Pro lead the class in storage capacity with large drives, and the performance needed to run high definition content with your NAS. Store thousands of full-length HD films and even more photographs on your private server. Think of it as your home cloud.
Seagate IronWolf Pro ST12000NE0007 - hard drive - 12 TB - SATA 6Gb/s
Hard drive - internal - 24x7 continuous operation, Hot-Plug Support, advanced format 512e, rotation vibration sensor, AgileArray
12 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
101.85 mm x 146.99 mm x 26.11 mm
705 g
5-year warranty
Bundled with
Seagate Rescue Data Recovery
12 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
705 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
250 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5 Watt (idle) , 7.8 Watt (active) , 0.8 Watt (standby) , 0.8 Watt (sleep)
ICES-003 Class B, NMB-3 Class B
Limited warranty - 5 years , Insurance - data recovery - 2 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Vibration Tolerance (non-operating)
2.27 g @ 10-500 Hz
