The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
- Seagate IronWolf ST12000VN0007 - hard drive - 12 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 12 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ), PowerChoice, advanced format 512e
- 101.85 mm x 146.99 mm x 26.11 mm
- 705 g
- 3-year warranty
- Capacity
- 12 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 4096
- 101.85 mm
- 146.99 mm
- 26.11 mm
- 705 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,000,000 hours
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Limited warranty - 3 years
- 5 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- 50 - 95% (non-condensing)
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
