Product
Seagate 10TB SkyHawk AI 3.3" SATA 6GB/s Surveillance Hard Drive
Quicklinx: D9XRWS00 Mfr#: ST10000VE0004
Select:
  • 10TB
Seagate SkyHawk AI is a purpose-built drive for artificial intelligence (AI)-enabled surveillance solutions.
Seagate SkyHawk AI ST10000VE0004 - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal
10 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Rotation vibration sensor, ImagePerfect firmware
101.85 mm x 146.99 mm x 26.11 mm
650 g
5 years warranty
Bundled with
Seagate Rescue Data Recovery
10 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
650 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
214 MBps
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7.2 Watt (active) , 4.9 Watt (idle) , 1.2 Watt (sleep) , 1.2 Watt (standby)
ICES-003 Class B, NMB-3 Class B
Limited warranty - 5 years , Insurance - data recovery - 2 years
5 °C
70 °C
Min Storage Temperature
-40 °C
