Seagate 10TB SkyHawk 256MB SATA 6Gb/s Surveillance HDD
Quicklinx: C8D0WS00 Mfr#: ST10000VX0004
SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
  • ImagePerfect firmware
    Supports 24×7 surveillance-optimized workloads tuned to record ~90% of the time and play back video footage the remaining 10%, and supports more cameras recording at higher resolutions than traditional drives.
  • High workload rating
    Allows SkyHawk to perform reliably in write-intensive surveillance systems - 3× the workload rating of a desktop-class drive.
  • Rotational vibration (RV) sensors
    Allow drives to maintain performance in RAID and multi-drive systems, giving customers the flexibility to grow with the booming NVR market and scale their systems when more storage is needed.
  • ATA streaming support
    Sustains recordings from up to 64 HD cameras for smooth, uninterrupted footage.
  • Lower power consumption
    Means a reduction in heat emissions, which improves reliability in surveillance solutions.
  • Tarnish-resistant components
    Help protect drive from environmental elements, increasing field reliability.
Seagate SkyHawk ST10000VX0004 - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal
10 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
RV Sensor, Native Command Queuing (NCQ), PowerChoice, Hot-Plug Support, TGMR recording technology, advanced format 512e, 24x7 availability, S.M.A.R.T.
101.85 mm x 146.99 mm x 26.11 mm
650 g
3-year warranty
10 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.85 mm
146.99 mm
26.11 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Power Consumption
6.8 Watt (active) , 4.42 Watt (idle) , 0.8 Watt (sleep) , 0.8 Watt (standby)
RoHS, China RoHS
Limited warranty - 3 years
5 °C
70 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
70 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
250 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
2.27 g @ 2-500 Hz
