Product
Seagate 10TB IronWolf NAS 256MB SATA 6Gb/s 7200RPM HDD
Quicklinx: C8CYWS00 Mfr#: ST10000VN0004
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 10TB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£255.20 ex VAT
£306.24 inc VAT
IronWolf - The Power of Agility for Everything NAS.
Tough. Ready. Scalable.
For everything NAS, there’s IronWolf. Always on and always working, IronWolf is enhanced with AgileArray™ technology for optimal reliability and system agility. Multi-user technology and extreme workload rates allow IronWolf to perform and scale up with your enterprise.
AgileArray and the Power of IronWolf for Your NAS
IronWolf is built with AgileArray. NAS-optimized for the best NAS experience possible, AgileArray focuses on drive balance, RAID optimization and power management.
• Dual-plane balance and Rotational Vibration (RV) sensors—available on 6TB, 8TB and 10TB capacities—mitigate vibration in multi-bay NAS enclosures for consistent performance and reliability
• RAID optimization increases performance and reliability with error recovery control for better data integrity
• Advanced power management saves energy and delivers power when the NAS needs it most
Do More With Multi-User Technology
Do more with your NAS with multi-user technology. Enabling user workloads of up to 180TB/year on IronWolf, multiple users can confidently upload and download data to a NAS server. Whether you’re a creative pro or a small business, IronWolf is on your side.
Be Creative Anywhere With IronWolf and Your NAS
Extensible and reliable storage helps keep you and your creative business on schedule. IronWolf is a great companion for your NAS for 24×7 remote access, backups and file sharing from anywhere, making sharing ideas easy. For growing agencies and the need for more storage, IronWolf is built to address NAS scalability challenges.
Grow Your Business NAS
A thriving small business needs storage that can thrive with it. IronWolf is optimized for NAS in multi-RAID environments that not only handle the vibration, but also handle the high user workload rate in a high data traffic network. Enter Multi-User Technology -- providing up to 180TB a year for IronWolf.
Game More With IronWolf Equipped NAS
Modern gaming consoles do double duty as home media servers, but limited storage makes keeping every file locally-stored a challenge. Gamers can move music and videos to a NAS equipped with IronWolf and use it as a storage target for media streaming. Get the most out of your console. With capacities ranging from 1TB to 10TB, you’ll be able to stream all the content you want from your NAS to your game console, and be able to view it on your high definition TV.
Dominate The Media
Build your home NAS media empire with IronWolf HDDs. IronWolf leads the class in storage capacity with drives as large as 10TB, and the performance needed to run high definition content with your NAS. Store thousands of full-length HD films and even more photographs on your private server. Think of it as your home cloud.
  • Optimized for NAS with AgileArray
    AgileArray is built for dual-plane balancing and RAID optimization in multi-bay environments with the most advanced power management possible.
  • Do more with multi-user technology
    Enables user workload rate of 180 TB/year. Multiple users can confidently upload and download data to the NAS server, knowing it can handle the workload, whether you’re a creative professional or small business.
Seagate IronWolf ST10000VN0004 - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal
10 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free, PowerChoice, Hot-Plug Support, advanced format 512e, 24x7 availability, S.M.A.R.T.
101.85 mm x 146.99 mm x 26.11 mm
650 g
3 years warranty
10 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.85 mm
146.99 mm
26.11 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6.8 Watt (active) , 4.42 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep)
Limited warranty - 3 years
5 °C
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
70 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
250 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
2.27 g @ 2-500 Hz
Form Factor: 3.5"
Type: Hard drive
Capacity: 10TB
Brand: Seagate
Price Range Ex VAT: 150 - 300
