Product
Seagate 10TB BarraCuda Pro 3.5" 256MB 7200RPM SATA 6Gb/s HDD
Quicklinx: C8C7WS00 Mfr#: ST10000DM0004
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 10TB
Spin Speed (rpm): 7200rpm
28 in stock
£290.47 ex VAT
£348.56 inc VAT
Lightning-fast performance and titanic storage up to 10TB give your desktop or creative professional system the edge you need to be your very best.
Seagate Barracuda Pro ST10000DM0004 - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal
10 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free, PowerChoice, Hot-Plug Support, advanced format 512e, S.M.A.R.T.
101.85 mm x 146.99 mm x 26.11 mm
650 g
5 years warranty
10 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.85 mm
146.99 mm
26.11 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
220 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
6.8 Watt (active) , 4.5 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep)
RoHS
Limited warranty - 5 years
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
70 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
250 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
2.27 g @ 2-500 Hz
Form Factor: 3.5"
Type: Hard drive
Capacity: 10TB
Brand: Seagate
Price Range Ex VAT: 150 - 300
