SBS Oceano Eco-friendly Wireless Speaker
Quicklinx: FWCTWS00 Mfr#: 8018417292194
Speaker Type: Speaker
Connection: Wireless
Stock Status: Clearance
10 left in stock
£20.79 ex VAT
£24.94 inc VAT
THE SOUND OF NATURE
Indulge your passion for music while protecting the environment. This 3 watt wireless speaker is the right choice for those who want a functional, practical and above all eco-friendly product. Take it with you everywhere thanks to the strap, or use the AUX cable to connect music players.
SUSTAINABILITY
This wireless speaker is made from 35% bio-degradable materials, while the Plastic Free packaging is made entirely of recycled paper and the ink used is environmentally friendly. By choosing products from the Collezione Oceano you also contribute to the cause of Marevivo, the Italian association for the defence of the sea and its resources.
HOW TO USE IT
Pair the speaker with your smartphone by accessing your device's Bluetooth settings. The 500 mAh capacity guarantees up to four hours of music listening. It can also act as a speakerphone when you receive calls.
This accessory also comes with an AUX input. Use it to listen to music when you can't do it wirelessly or you want to connect your MP3 player.
WITH YOU EVERYWHERE
The handy wrist strap is useful for carrying the speaker with you at all times. You can hang it at home wherever you want to play your favourite music while you study or cook, or hook it up to a backpack and carry it with you at all times.
SBS Oceano - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Nominal Output Power
3 Watt
Frequency Response
100 - 15000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - mono - 3 Watt - 100 - 15000 Hz - <15% THD - 4 Ohm - active
Power Options
USB charging
Speaker battery rechargeable
Microphone
Enclosure Material
35% biodegradable material
Design Features
Built-in hand strap
Speaker System
Speaker Type
Active
3 Watt
Frequency Response
100 - 15000 Hz
Amplifier
Integrated
Bluetooth 5.0
Transmission Range
10 m
Controls
Power on/off
Speaker System Details
Speaker Details
Speaker - mono - 3 Watt - 100 - 15000 Hz CFR - <15% THD - 4 Ohm - active
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power input (5 pin Micro-USB Type B)
Micro-USB charging cable
Power Source
Options
USB charging
Rechargeable
Capacity (Ah)
500 mAh
Run Time (Up To)
4 hours
Recharge Time
2 hours
Brand: SBS
Price Range Ex VAT: 0 - 50
