PROTECT THE OCEAN AND YOUR SMARTPHONE
A cover to protect the planet and your iPhone 11 Pro: the eco-friendly case from the Collezione Oceano is designed to protect your device without polluting.
By choosing Ocean you contribute to the cause of Marevivo, the Italian association for the defence of the sea and its resources.
CHOOSE ECO-FRIENDLY: DO NOT POLLUTE
This soft cover is entirely compostable: it is made from two eco-friendly materials (PBAT and PLA) that ensure elasticity and thermal and moisture resistance. When you decide to dispense with the protection, you will be able to dispose of it through separate collection in the wet/organic waste.
THE IDEAL PROTECTION FOR YOUR DEVICE
The Ocean case offers excellent protection for your device without weighing it down. The power and volume control buttons are covered, while the camera, connectors and sensors have dedicated openings for convenient use. The cover is ideal for avoiding scratches, absorbing small bumps and preventing dust infiltration.
PLASTIC FREE PACKAGING
The package containing the cover is plastic-free and made of 100% recycled paper. Eco-friendly ink has been used for printing.
Protect the ocean and your smartphone
A cover to protect the planet and your smartphone: the eco-friendly case from Oceano is designed to protect your device without polluting. -
Choose eco-friendly: do not pollute
This soft cover is entirely compostable: it is made of two eco-friendly materials (PBAT and PLA) that ensure elasticity and thermal and moisture resistance. You will be able to dispose of it through separate collection in the wet/organic waste. -
The ideal protection for your device
The Oceano case offers excellent protection for your device without weighing it down. The power and volume control buttons are covered, while the camera, connectors and sensors have dedicated openings for convenient use. The cover is ideal for avoiding scratches, absorbing small bumps and preventing dust infiltration.
- SBS Oceano Eco Cover - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polylactide (PLA), polybutylene adipate terephthalate (PBAT)
- Dolphin
- Designed For
- Apple iPhone 11 Pro
- Material
- Dolphin
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Temperature-resistant, scratch-resistant, moisture-resistant, dust protection
- Cover Type
- Back cover
- Designed For
