Product
Brand
Sapphire Technology Radeon R9 380 ITX OC 2GB GDDR5 PCIe Graphics Card
Quicklinx: BF2JWS00 Mfr#: 11242-00-20G
The SAPPHIRE ITX Compact R9 380 edition has been developed especially for small form factor PC systems. This model features a shorter PCB, measuring only 171mm long, and an efficient heatpipe cooler with a single dual-ball bearing fan. With its 2GB frame buffer it is no slouch despite its small size. Sharing the latest AMD GCN core with the NITRO and Dual-X models, the SAPPHIRE ITX Compact R9 380 supports DirectX 12, TrueAudio, AMD FreeSync and Ultra HD. With a SAPPHIRE Performance Index of 3 it is guaranteed to deliver a great gaming experience in high detail at 1080p and beyond.
Introducing AMD LiquidVR
LiquidVR™ is an AMD initiative dedicated to making VR as comfortable and realistic as possible by creating and maintaining what's known as "presence" -- a state of immersive awareness where situations, objects, or characters within the virtual world seem "real." Guided by close collaboration with key technology partners in the ecosystem, LiquidVR™ uses AMD's GPU software and hardware sub-systems to tackle the common issues and pitfalls of achieving presence, such as reducing motion-to-photon latency to less than 10 milliseconds. This is a crucial step in addressing the common discomforts, such as motion sickness, that may occur when you turn your head in a virtual world and it takes even a few milliseconds too long for a new perspective to be shown.
AMD Freesync technology
No stuttering. No tearing. Just gaming.
AMD FreeSync™ technology allows a compatible graphics card and monitor to dynamically change frame rates for the optimum display quality without tearing or stuay.
DirectX® 12
DirectX® 12 is a new, "console-like" graphics API from Microsoft® that empowers game developers with more direct and obvious control of PC hardware. This direct or "explicit" control better exposes the hardware resources of AMD Radeon™ GPUs to yield higher hardware throughput and, ultimately, more performance for users. To put it simply: much more efficient hardware through smarter software! At the discretion of a game developer, this superior efficiency can be spent on higher framerates, lower latency (VR), lower power consumption, better image quality, or some calculated balance of all four. In any scenario, gamers stand to benefit greatly from choosing AMD hardware to run their favorite DirectX® 12 game.
Sapphire RADEON R9 380 ITX OC - Compact Edition - graphics card - Radeon R9 380 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 380
2 GB GDDR5
Core Clock
980 MHz
Stream Processors
1792
Effective Memory Clock
5.6 GHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI (Single-Link): 1920 x 1200 / DVI (Dual-Link): 2560 x 1600 / DisplayPort: 4096 x 2160
Max Monitors Supported
4
DVI-D (dual link) , HDMI , 2 x Mini DisplayPort
API Supported
DirectX 12, OpenGL 4.5, OpenCL 2.0
3.7 cm x 17 cm x 11.615 cm
Package Type
Lite retail
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 380
Core Clock
980 MHz
Stream Processors
1792
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Dual Slot Fan Cooler, Dual Bios, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, AMD PowerTune technology, Shader Model 5.0, Graphics Core Next (GCN), AMD ZeroCore Power technology, Video Codec Engine (VCE), Dual ball Bearing Fan, AMD TrueAudio Technology, FreeSync Technology, AMD LiquidVR Technology, Virtual Super Resolution (VSR)
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5.6 GHz
Bus Width
256-bit
Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Required Power Supply
500 W
Additional Requirements
CD-ROM, 8 pin PCI Express power connector
225 Watt
Software Included
Display drivers
3.7 cm
17 cm
11.615 cm
Package Type
Lite retail
