The SAPPHIRE R7 250 1 GB now has the GDDR5 memory clocked at 4500 MHz effective, and runs with a core clock speed of 800 MHz.
HDMI (with 3D)
Support for Deep Color, 7.1 High Bitrate Audio, and 3D Stereoscopic, ensuring the highest quality Blu-ray and video experience possible from your PC. -
DisplayPort 1.2
Doubling the effective bandwidth of previous DisplayPort implementations, DisplayPort 1.2 now includes support for Multi-Stream, allowing you to drive up to four separate monitors from a single DisplayPort 1.2 connector (requires DP1.2 monitors or Multi-Stream compatible hub), Stereoscopic 3D monitor support and adds support for high quality, lossless, 7.1 channel audio formats. -
Dual-Link DVI-I
Equipped with the most popular Dual Link DVI (Digital Visual Interface), this card is able to display ultra high resolutions of up to 2560 x 1600 at 60Hz. -
Advanced GDDR5 memory technology
GDDR5 memory provides twice the bandwidth per pin of GDDR3 memory, delivering more speed and higher bandwidth. -
AMD Stream technology
Accelerate the most demanding applications with AMD Stream technology and do more with your PC. AMD Stream technology allows you to use the teraflops of compute power locked up in your graphics processer on tasks other than traditional graphics such as video encoding, at which the graphics processor is many, many times faster than using the CPU alone. -
AMD Avivo HD (DVD/HD-DVD/Blu-ray playback)
Watch the hottest Blu-ray movies or other HD content at full 1080p display resolution and beyond and enjoy a more feature rich experience with enhanced Unified Video Decoder(UVD) -
AMD CrossFireX Multi-GPU technology
Triple or Quadruple gaming power with AMD CrossFireX Multi-GPU Technology. AMD CrossFireX technology supports up to four graphics cards to be used in a single system. -
AMD HD3D technology
Enjoy the most immersive experience possible with full support for High Definition Stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth when using compatible 3D displays/glasses/software. -
28 nm GCN (Graphic Core Next) architecture
The 28nm GCN architecture's more efficient process technology puts more transistors in less space, enabling a dramatic increase in processing power -
PCI Express 3.0
PCI-Express 3.0 delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU (GPU communication-up to 16GB/sec in each direction), maximizing the performance from your GPU when paired with the latest platforms. -
AMD Eyefinity 2.0
The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better: The enhancements for AMD Radeon HD7000 series include: Stereo 3D-multi-display stereoscopic 3D support via DisplayPort 16K X 16K maximum display group resolution-output up to 268 megapixels per GPU. -
OpenGL 4.2
OpenGL 4.2 improves the GPU efficiency by improving the shader process operation and capturing GPU tessellated geometry. The process of modifying an arbitrary subset of compress texture is also simplified. The memory management in handling shaders is more efficient as well. -
Best Microsoft DirectX11 support
The tessellation performance on AMD Radeon HD7000 is up to 2x faster than the previous generation, and DirectCompute performance is also faster to accelerate advanced post-processing, filtering, and anti-aliasing techniques. Direct X11 games has never looked this good. -
Dolby TrueHD and DTSHD master audio support
Support for copy protected, high bandwidth, 7.1 channel surround sound over HDMI. Get a fully immersive, high definition audio experience with the latest Blu-ray movies. (Requires a DVI to HDMI dongle on some models, an HD capable monitor and a Blu-ray drive) -
Anti-aliasing features
Supports advanced AA (Anti-aliasing) features to maximize your enjoyment of high definition gaming. -
AMD PowerTune technology
AMD PowerTune is a breakthrough technology that sets an entirely new direction for maximum performance at TDP. It allows the GPU to be designed with higher engine clock speeds which can be applied on the broad set of applications that have thermal headroom. -
Display flexibility
Offers an incredible choice of the latest display connectivity options natively on the board, including dual-link DVI-I, DisplayPort and HDMIalong with adapters to ensure compatibility with your legacy analogue VGA monitor. -
AMD App acceleration
AMD App acceleration is a set of technologies designed to improve video quality and enhance application performance. Full enablement of some features requires support for OpenCL, DirectCompute or DirectX Video Acceleration (DXVA). -
AMD PowerPlay with ZeroCore power technology
AMD PowerPlay is a power management technology in response to the GPU loading, AMD PowerPlay automatically manages the power consumption.AMD ZeroCore Power technology allows your AMD Radeon GPU to consume virtually no power when in idle state5. When used with AMD CrossFire technology, it shuts down additional GPUs when they're not in use. -
Cutting-edge Quad HD display support (4K support)
The display resolution on AMD Radeon HD7000 series is quadrupled to the resolution of 4K x 2K(4096 x 2160) from the outputs of DisplayPort 1.2 and HDMI.
- Sapphire RADEON R7 250 - graphics card - Radeon R7 250 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R7 250
- Memory
- 1 GB GDDR5
- Core Clock
- 800 MHz
- Stream Processors
- 512
- Effective Memory Clock
- 4.5 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
- Max Monitors Supported
- 3
- Interfaces Details
- DVI-I (dual link) , Micro-HDMI , Mini DisplayPort , VGA - with adapter , DisplayPort - with adapter , HDMI - with adapter
- API Supported
- DirectX 11, OpenGL 4.2
- 1.8 cm x 17 cm x 6.7 cm
- Package Type
- Lite retail
- Bus Type
- Graphics Engine
- AMD Radeon R7 250
- Core Clock
- 800 MHz
- Stream Processors
- 512
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 3
- API Supported
- High dynamic-range (HDR) rendering, Avivo HD Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Stream technology, AMD App Acceleration, Dolby True HD support, DTS-HD Master Audio support, AMD Eyefinity Technology 2.0, Multi-Sample Anti-Aliasing (MSAA), Graphics Core Next (GCN), AMD ZeroCore Power technology, cutting-edge Quad HD display support, 24x Custom Filter Anti-Aliasing (CFAA)
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 4.5 GHz
- Bus Width
- 128-bit
- Min RAM Size
- 4 GB
- Required Power Supply
- 400 W
- Additional Requirements
- CD-ROM
- Included Accessories
- ATX bracket
- Cables Included
- 1 x DVI-VGA adapter , 1 x Mini DisplayPort-DisplayPort cable , 1 x micro-HDMI-HDMI cable
- Software Included
- Drivers & Utilities, AMD Catalyst Control Center
- WHQL
- 1.8 cm
- 17 cm
- 6.7 cm
- Package Details
- Lite retail
