The SAPPHIRE R7 240 with Boost now has the latest DDR3 memory clocked at 1800MHz effective, and runs with a core clock speed of 730 MHz which with PowerTune Dynamic Boost rises to 780 MHz on the engine.
Specification
- Display Support 2 x Maximum Display Monitor(s) support
- Output D-Sub(VGA), 1 x HDMI (with 3D), 1 x Dual-Link DVI-D
- GPU 730 MHz Core Clock, 28 nm Chip, 320 x Stream Processors
- Video Memory 2048 MB Size, 128 -bit DDR3, 1800 MHz Effective
- Dimension 145(L)X95(W)X15(H) mm Size, 2 x slot
- Software Driver CD, SAPPHIRE TriXX Utility
HDMI (with 3D)
Support for Deep Color, 7.1 High Bitrate Audio, and 3D Stereoscopic, ensuring the highest quality Blu-ray and video experience possible from your PC. -
AMD Stream Technology
Accelerate the most demanding applications with AMD Stream technology and do more with your PC. AMD Stream Technology allows you to use the teraflops of compute power locked up in your graphics processer on tasks other than traditional graphics such as video encoding, at which the graphics processor is many, many times faster than using the CPU alone. -
AMD Avivo HD (DVD/HD-DVD/Blu-ray Playback)
Watch the hottest Blu-ray movies or other HD content at full 1080p display resolution and beyond and enjoy a more feature rich experience with enhanced Unified Video Decoder (UVD). -
AMD CrossFireX Multi-GPU Technology
Triple or Quadruple gaming power with AMD CrossFireX Multi-GPU Technology.AMD CrossFireX technology supports up to four graphics cards to be used in a single system. -
AMD HD3D Technology
Enjoy the most immersive experience possible with full support for High Definition Stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth when using compatible 3D displays / glasses / software. -
28 nm GCN (Graphic Core Next) Architecture
The new and 28nm GCN Architecture with more efficient process technology puts more transistors in less space, enabling a dramatic increase in Processing Power. Crank the settings, devastate your enemies and bear witness to absurdly high frame rates with AMD Radeon HD7000 series graphics card-DirectX 11 has never looked this good. Maximum setting and crazy performance shouldn't be a compromise. The AMD Radeon HD7900 Series with the new 28 nm GCN Architecture assures that it's not. -
PCI Express 3.0
PCI-Express 3.0 delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU (GPU communication-up to 16GB/sec in each direction), maximizing the performance from your GPU when paired with the latest platforms. -
DirectX 11.2
The tessellation performance on AMD Radeon R7/ R9 series is up to 2X faster than the previous generation, and DirectCompute performance is also faster to accelerate advanced post-processing, filtering, and anti-aliasing techniques. Direct X11 games has never looked this good. -
OpenGL 4.3
OpenGL 4.3 improves the GPU efficiency by improving the shader process operation and capturing GPU tessellated geometry. The process of modifying an arbitrary subset of compress texture is also simplified. The memory management in handling shaders is more efficient as well. -
AMD Catalyst Control Center
The AMD Catalyst Control Center software application gives you complete control over the performance and visual quality of your SAPPHIRE AMD Radeon based graphics card allowing for the best experience on your PC. -
Dolby TrueHD and DTSHD Master Audio Support
Support for copy protected, high bandwidth, 7.1 channel surround sound over HDMI. Get a fully immersive, high definition audio experience with the latest Blu-ray movies. (Requires a DVI to HDMI dongle on some models, an HD capable monitor and a Blu-ray drive) -
Anti-aliasing features
Supports advanced AA (Anti-aliasing) features to maximize your enjoyment of high definition gaming.
- Sapphire RADEON R7 240 with Boost - graphics card - Radeon R7 240 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0
- Graphics Engine
- AMD Radeon R7 240
- Memory
- 2 GB DDR3
- Core Clock
- 730 MHz
- Boost Clock
- 780 MHz
- Stream Processors
- 320
- Effective Memory Clock
- 1.8 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- HDMI: 4096 x 2160 / VGA: 2048 x 1536
- Max Monitors Supported
- 2
- Interfaces Details
- DVI-D (dual link) , HDMI , VGA
- API Supported
- OpenCL, DirectCompute, OpenGL 4.3, DirectX 11.2
- 1.5 cm x 14.5 cm x 9.5 cm
- Package Type
- Lite retail
- Graphics card
- Bus Type
- PCI Express 3.0
- Graphics Engine
- AMD Radeon R7 240
- Core Clock
- 730 MHz
- Boost Clock
- 780 MHz
- Stream Processors
- 320
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 2
- API Supported
- Avivo HD Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Stream technology, AMD App Acceleration, Deep Color technology, Dolby True HD support, DTS-HD Master Audio support, AMD HD Media Accelerator, Multi-Sample Anti-Aliasing (MSAA), Graphics Core Next (GCN), AMD ZeroCore Power technology, 24x Custom Filter Anti-Aliasing (CFAA), AMD Unified Video Decoder (UVD), HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.8 GHz
- Bus Width
- 128-bit
- OS Required
- Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- Min RAM Size
- 1 GB
- Required Power Supply
- 400 W
- Additional Requirements
- CD-ROM, adjacent PCI slot
- Software Included
- Drivers & Utilities, Sapphire TriXX, AMD Catalyst Control Center
- WHQL
- 1.5 cm
- 14.5 cm
- 9.5 cm
- Package Details
- Lite retail
