THE SECRET INGREDIENT FOR SMART DEVICES
A slim, power efficient drive for embedded applications and mobile devices, the Z400s brings new levels of performance and intelligence to electronic signs, point-of-sale systems, notebooks and other products.
Low Power and High Performance in One Package
The Z400s SSD can outperform HDDs by a factor of five at 1/20th the power consumption at a price point on par with HDDs.
Built to Go The Distance
High endurance and reliability are the hallmark of an embedded solution. The Z400s can provide up to 1.7 million hours of continual use and exceptional stability during peak activity.
A TCO For The Real World
Exceptional reliability, low maintenance and high performance all add up to a lower total cost of ownership.
Capacity - 128GB
Sequential Read/Write - Up to 546/342MB/s
Random Read/Write - Up to 33/62k IOPS
Interface - SATA Revision 3.2 (6 Gb/s) backward compatible to SATA Revision 2.0 (3 Gb/s) and SATA Revision 1.0 (1.5 Gb/s)
Endurance - 72 TBW
Reliability and TCO
The SanDisk Z400s SSD can improve total cost of ownership (TCO) by reducing downtime and service requests due to hard drive failures. Its solid-state design means there are no moving parts, making it shock-resistant and much more reliable than traditional HDDs. -
Endurance
The Z400s is able to sustain a high volume of transactions, which is well-suited for POS systems, ATMs, and other embedded platforms that handle frequent transactions. -
Low power
Its low power characteristics mean it generates very little heat, making the Z400s perfect for green and fanless designs.
- SanDisk Z400s - SSD - 128 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 128 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, DEVSLP SATA low power mode, Windows WHCK certified
- 69.85 mm x 100.5 mm x 7 mm
- 30 g
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 128 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.5 mm
- 7 mm
- 30 g
Performance
- SSD Endurance
- 72 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 546 MBps (read) / 182 MBps (write)
- 4KB Random Read
- 35500 IOPS
- 4KB Random Write
- 43300 IOPS
Reliability
- MTBF
- 1,750,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 1.6 Watt (active) , 1600 mW (read) , 1900 mW (write) , 30 mW (average)
- UL, TUV, VCCI, BSMI, FCC, KC
- Package Type
- Retail
- Limited warranty - 3 years
- 0 °C
- 70 °C
