SanDisk Ultra SDHC /SDXC UHS-I Memory Cards are ideally suited for compact to mid-range point-and-shoot digital cameras and camcorders. With their large capacity and outstanding speed to make sure you don't miss the moment, you have all the memory and performance you need to capture thousands of high resolution photographs and hours of Full HD (1080p) videos. SanDisk Ultra SDHC/SDXC UHS-I Memory Cards incorporate ultra-fast data transfer performance speeds of up to 40MB/s, allowing you to transfer images more quickly from your digital camera or camcorder to your desktop or laptop. Designed to keep on working even in testing conditions, SanDisk Ultra SDHC/SDXC UHS-I Memory Cards are waterproof, temperature proof, shock proof, magnet proof and X-ray proof . They are precisely designed, engineered and built by the world's largest provider of flash memory cards.
Make more of speed
SanDisk Ultra SDHC/SDXC UHS-I Memory Cards are twice as fast as standard SDHC/SDXC cards, so that you get more from your camera or camcorder. They meet Class 10 performance ratings, ensuring that you can take picture-perfect Full HD (1080p) video. They are also ideal for taking a series of high-resolution photos in quick succession (burst-mode shooting) or if you plan to use RAW image file format on a DSLR. -
The capacity you need to capture more images
Storing all of the high definition images and Full HD (1080p) videos that digital cameras and camcorders are capable of capturing can be a problem. SanDisk Ultra SDHC/SDXC UHS-I Memory Cards make sure that you never miss a shot because your camera's memory is full. That's because even with Full HD video and high resolution images hungry for storage space, you have plenty of headroom, just in case. -
Save yourself some time
With SanDisk Ultra SDHC/SDXC UHS-I Memory Cards, you can transfer photos and videos to your PC at read speeds of up to 40MB/s, giving you more time to crop, edit and adjust your images. -
Capture the shot you want in testing conditions
Photographers don't only shoot in comfortable studios. Sometimes the memory cards for cameras they use need to work in extreme conditions. SanDisk Ultra SDHC/SDXC UHS-I Memory Cards are waterproof, temperature proof, shock proof, magnet proof and X-ray proof , so that you can capture the images you want in any environment, from desert to mountain stream. -
Reliability you can count on
SanDisk develops and engineers its memory cards to maximise reliability, so you can count on your SanDisk Ultra SDHC/SDXC UHS-I Memory Card to store your important memories.You can shoot with total peace of mind. SanDisk Ultra SDHC/SDXC UHS-I Memory Cards are backed by a 10-year warranty .
- SanDisk Ultra - flash memory card - 8 GB - SDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- SDHC UHS-I Memory Card
- Storage Capacity
- 8 GB
- Speed Rating
- UHS Class 1 / Class10 - 266x
- Localisation
- Europe
- Microsoft Certification
- Compatible with Windows 7
- Limited lifetime warranty (Germany and regions not recognizing limited lifetime warranty - 30 years)
- Product Type
- Flash memory card
- Storage Capacity
- 8 GB
- Localisation
- Europe
- Speed Rating
- 266x
- Speed Class
- Read Rate
- Up to 40 MB/s
- Form Factor
- Shockproof, magnetic-proof, waterproof, write protection switch, vibration-proof, X-ray-proof, temperature-proof
- Included Accessories
- Case
- Limited warranty - lifetime , Germany: limited warranty - 30 years
