Your basket is empty
Sandisk Ultra Flash memory card 8GB Class 10 SDHC
Quicklinx: 9VMCWS00 Mfr#: SDSDUN-008G-G46
SanDisk Ultra SDHC /SDXC UHS-I Memory Cards are ideally suited for compact to mid-range point-and-shoot digital cameras and camcorders. With their large capacity and outstanding speed to make sure you don't miss the moment, you have all the memory and performance you need to capture thousands of high resolution photographs and hours of Full HD (1080p) videos. SanDisk Ultra SDHC/SDXC UHS-I Memory Cards incorporate ultra-fast data transfer performance speeds of up to 40MB/s, allowing you to transfer images more quickly from your digital camera or camcorder to your desktop or laptop. Designed to keep on working even in testing conditions, SanDisk Ultra SDHC/SDXC UHS-I Memory Cards are waterproof, temperature proof, shock proof, magnet proof and X-ray proof . They are precisely designed, engineered and built by the world's largest provider of flash memory cards.
SanDisk Ultra - flash memory card - 8 GB - SDHC UHS-I
Flash memory card
SDHC UHS-I Memory Card
Storage Capacity
8 GB
Speed Rating
UHS Class 1 / Class10 - 266x
Europe
Microsoft Certification
Compatible with Windows 7
Limited lifetime warranty (Germany and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
8 GB
Compatibility
Non-specific
Europe
Speed Rating
266x
SD Speed Class
Read Rate
Up to 40 MB/s
Shockproof, magnetic-proof, waterproof, write protection switch, vibration-proof, X-ray-proof, temperature-proof
Case
Limited warranty - lifetime
