The ultra-small, low-profile 64GB SanDisk Ultra Fit High-Speed USB 3.0 Flash Drive offers incredible high-speeds in a tiny package. Its clever design means you can plug it neatly into notebooks, tablets, TVs or car audios, even in the tightest spaces. Then you can just leave it there for easy access to extra storage, without fear of knocking or breaking it. If you would rather move media extra-fast between devices, its USB 3.0 speeds mean that now you can enjoy write speeds up to 10x faster than standard USB 2.0 drives and transfer a full-length movie in 40 seconds . It also gives you a big 64GB of storage space, ready to hold massive files. The included SanDisk SecureAccess software provides password protection and 128-bit encryption for your private files, giving you extra reassurance that your files will be safe when you're taking them out and about.
The speed your lifestyle demands
SanDisk Ultra Fit USB 3.0 High-speed Flash Drives transfer files to the drive up to 10x faster than standard USB 2.0 drives, so can transfer a full-length movie in just 40 seconds. -
The capacity you need to store more
The 64GB SanDisk Ultra Fit High-Speed USB 3.0 Flash Drive gives you plenty of room for whatever you want to take around with you. It's easy to live your life the way you want: just carry around loads of photos, songs, videos or massive work files ready for using and sharing. -
Speed with convenience
With its low profile and high speeds – up to 130MB/s read speed, for example – the SanDisk Ultra Fit High-Speed USB 3.0 Flash Drive makes storing and transferring data even faster and more convenient. -
Stay protected with SanDisk
SanDisk SecureAccess software comes as standard with the 64GB SanDisk Ultra Fit High-Speed USB 3.0 Flash Drive, making it easy to protect personal or critical files such as business presentations or legal documents. Simply drag and drop files into the vault, and they'll be protected by a personal password and automatic 128-bit AES encryption. This means that your content will stay private and secure when you are out and about or if you store the drive away for safe keeping. -
Compatibility
The 64GB SanDisk Ultra Fit High-Speed USB 3.0 Flash Drive is optimised for laptops and devices with USB 3.0 ports. It is also backwards compatible with older devices that have USB 2.0 ports, so you can be assured that you can still obtain the most from them. -
Reassurance with performance
You can enjoy extreme speed with total peace of mind. The 64GB SanDisk Ultra Fit High-Speed USB 3.0 Flash Drive is backed by a 5-year warranty.
- SanDisk Ultra Fit - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 64 GB
- Encryption Algorithm
- 128-bit AES
- Localisation
- Latin America, Asia Pacific, Middle East, Africa, Europe
- Software Included
- RescuePRO (1 year download), SanDisk SecureAccess 3.0
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Windows 8
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- 128-bit AES
- Localisation
- Read Rate
- Up to 130 MB/s
- Interface Type
- USB 3.0
- AES-128
- Software Included
- OS Required
- Limited warranty - 5 years
- 15.9 mm
- 19.1 mm
- 8.8 mm
- 0 °C
- 45 °C
