Sandisk Ultra - USB 3.0 - 64GB
Quicklinx: 92JMWS00 Mfr#: SDCZ48-064G-U46
Capacity: 64GB
Interface: USB 3.0
More than 50 In Stock
£6.72 ex VAT
£8.06 inc VAT
The faster you can transfer content, the faster you can start having fun – or the faster you can get your work done. The 64GB SanDisk Ultra High-Speed USB 3.0 Flash Drive offers ultra-fast transfer speeds of up to 100MB/s. This means that you can transfer files in just a fraction of the time USB 2.0 technology can support. It also includes SanDisk SecureAccess software with 128-bit file encryption and password protection so that even your largest private files stay protected, yet you can still share the files you want to.
  • Move Files Quickly with Faster Transfer Speeds
    With transfer speeds of up to 100MB/s, the SanDisk Ultra USB 3.0 Flash Drive reduces the time you'll spend waiting for files to move from the flash drive to your computer. Enabled for USB 3.0 this fast drive lets you transfer and store large files up to ten times faster than standard USB 2.0 drives.
  • High-Capacity Drive Accommodates Large Files
    Offered in capacities up to 256GB, the SanDisk Ultra USB 3.0 Flash Drive can hold all your favorite media and important documents, including high-resolution photos, MP3s, movies, presentations, and graphic files.
  • Stylish, Portable Design
    With its sleek black design, the SanDisk Ultra USB 3.0 Flash Drive is as stylish as it is practical. This compact and portable drive can easily travel with you in a pocket or handbag.
  • SanDisk SecureAccess Software Keeps Files Private
    The SanDisk Ultra USB 3.0 Flash Drive includes SanDisk SecureAccess software, which lets you set up a password-protected private folder on your drive . Your files will be secured with 128-bit AES encryption to help keep them confidential, even when sharing the drive with others.
  • Warranty
    The SanDisk Ultra USB 3.0 Flash Drive is backed by a five-year warranty .
SanDisk Ultra - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Encryption Algorithm
128-bit AES
Europe
Software Included
SanDisk RescuePRO, SanDisk SecureAccess
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Windows 8
Microsoft Certification
Compatible with Windows 7
5-year warranty
USB flash drive
Storage Capacity
64 GB
128-bit AES
Europe
Read Rate
Up to 130 MB/s
Interface Type
USB 3.0
Password protection, retractable connector, key ring loop
AES-128
Software Included
Limited warranty - 5 years
21.3 mm
56.8 mm
10.8 mm
45 °C
Capacity: 64GB
Interface: USB 3.0
Brand: Sandisk
