Robust storage capacity
With a spacious 1 TB capacity, this solid state drive accommodates large files including videos, high-resolution images, and extensive projects. -
High-speed performance
Achieve data transfer speeds of up to 2000 MBps, streamlining your workflow and allowing for rapid access to important files. -
Durable design
Constructed to withstand adverse conditions, this drive is both water-resistant and dust-resistant, making it a reliable choice for outdoor and on-the-go usage. -
Advanced connectivity
Equipped with USB-C and supporting USB 3.2 Gen 2x2 technology, this hard drive delivers quick data transfer rates, enhancing compatibility with modern devices. -
Wide temperature range
Operates effectively in a range of temperatures, ensuring dependable performance whether in hot or cold environments.
- SanDisk Creator Pro - SSD - 1 TB - USB 3.2 Gen 2x2
- Solid state drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.2 Gen 2x2 - USB-C
- Data Transfer Rate
- 20 Gbps (USB 3.2 Gen 2x2)
- Water resistant, dust-resistant
- 57.83 mm x 110.8 mm x 10.31 mm
- 77.5 g
- 5-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.2 Gen 2x2
- 57.83 mm
- 110.8 mm
- 10.31 mm
- 77.5 g
Performance
- Interface Transfer Rate
- Internal Data Rate
- 2000 MBps (read) / 2000 MBps (write)
Expansion & Connectivity
- 1 x USB 3.2 Gen 2x2 - 24 pin USB-C
- Software Included
- Adobe Creative Cloud (1 month membership)
- OS Required
- Windows 10 or later, Apple macOS 14 or later
- Cables Included
- 1 x USB-C cable - external , 1 x USB-C to USB-A adapter - external
- IP65
- Shipping Width
- 10.3 cm
- Shipping Depth
- 13.6 cm
- Shipping Height
- 3.45 cm
- Limited warranty - 5 years
- 0 °C
- 45 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
