Versatile compatibility
This USB flash drive supports both USB-C and Apple Lightning interfaces, making it compatible with a wide range of devices for flexible use. -
Robust build quality
Constructed with a metal body, the SanDisk Creator Phone Drive is designed to endure daily wear and tear while maintaining a sleek profile. -
Reliable data transfer speed
With a read rate of 90 MB/s, users can quickly transfer files, enhancing productivity and ensuring smooth workflows.
- SanDisk Creator Phone Drive - USB flash drive - 128 GB
- Product Type
- USB flash drive
- Interface Type
- USB-C / Apple Lightning
- Storage Capacity
- 128 GB
- Software Included
- Adobe Photoshop Lightroom (3 months trial)
- OS Required
- Apple MacOS 12.0 or later, Microsoft Windows 10 or later, Android, Apple iOS 13 or later
- 2-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 128 GB
- Read Rate
- Up to 90 MB/s
- Interface Type
- Metal body
- Software Included
- OS Required
- Limited warranty - 2 years
- 5 mm
- 15.2 mm
- 8.7 mm
- 20.3 g
- Shipping Width
- 9.6 mm
- Shipping Depth
- 101.6 mm
- Shipping Height
- 152.4 mm
- 0 °C
- 45 °C
