The Optimus MAX 4TB SAS SSD is the first SSD of its kind to deliver SAS performance and features at the cost of SATA SSD-like prices for enterprise, cloud and virtualized data centers. This 4TB* SSD enables organization to transition to a leaner infrastructure model, for maximum total cost of ownership (TCO) savings and surpasses the current high capacity 2.5" SAS SSDs and 2.5" SAS HDDs on the market today. The Optimus MAX SSD is optimized for read-intensive application workloads such as, Data Warehousing, Media Streaming, Web Servers, Video on Demand (VOD), and Web-based Applications with a typical workload comprised of a 90/10 read/write mix. This 4TB SAS SSD alleviates I/O bottlenecks by providing high-density storage for efficient data throughput to deliver, high performance, superior reliability and enhanced endurance for maximum application scalability.
The Optimus MAX 4TB SAS SSD features industry leading 19nm eMLC with a native 6Gb/s SAS interface and provides data transfer rates of up to 500/500MB/s sequential read/ write and performance of up to 85K/11K IOPS random read/write. This SSD offers 0.5 full drive writes per day (DWPD) with a limited 5 year warranty. The Optimus MAX 4TB SAS SSD removes the flash capacity barrier for replacing 10K and 15K RPM SAS HDDs and provides an ideal solution for true storage stack applications.
Guardian Technology Platform
The Optimus MAX 4TB SSD is powered by SanDisk’s innovative Guardian Technology Platform, a comprehensive suite of enterprise features comprised of FlashGuard, DataGuard and EverGuard technologies.
FlashGuard Technology combines Aggregated Flash Management, which treats all flash elements as a single system, and Advanced Signal Processing, which dynamically adjusts flash parameters throughout the life of the SSD, to reliably extract significantly more life from commercial-grade MLC flash, making it suitable for mixed-use application workloads.
DataGuard Technology features full data path protection, safeguarding user data from corruption along all data paths in the SSD. DataGuard also protects the SSD against loss of data at the page and block levels using a unique feature called F.R.A.M.E. (Flexible Redundant Array of Memory Elements). F.R.A.M.E. acts as a data recovery feature that enables the recovery of user data even after catastrophic events such as flash page or block failures.
- SanDisk Optimus MAX - SSD - 4 TB - SAS 6Gb/s
- Solid state drive - internal
- Capacity
- 4 TB
- NAND Flash Memory Type
- 19nm enterprise multi-level cell (eMLC)
- Form Factor
- 2.5"
- Interface
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Power Failure Recovery, FlashGuard Technology, DataGuard Technology, EverGuard Technology, Guardian Technology Platform, built-in backup power circuitry, Flexible Redundant Array of Memory Elements (F.R.A.M.E.)
- 69.85 mm x 100.2 mm x 15 mm
- 5-year warranty
- Capacity
- 4 TB
- Form Factor
- 2.5"
- Interface
- SAS 6Gb/s
- 69.85 mm
- 100.2 mm
- 15 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps (read) / 500 MBps (write)
- 4KB Random Read
- 65000 IOPS
- 4KB Random Write
- 10000 IOPS
Reliability
- MTBF
- 2,500,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x SAS 6Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 7 Watt (active)
- Limited warranty - 5 years
- 0 °C
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (operating)
- 1000 g @ 0.5 ms half-sine pulse
- Shock Tolerance (non-operating)
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 2.17 g @ 7-800 Hz
