Sandisk FC 128GB Extreme Pro CL10 Micro-SDXC Reader
Quicklinx: DQ77WS00 Mfr#: SDSQXPJ-128G-GN6M3
With the SanDisk Extreme PRO microSDXC UHS-II Card, you can now get to your videos faster than ever before. Use the included USB 3.0 reader for convenient transfers and take the bottleneck out of enjoying even your most massive 4K UHD video files . Finally your memory card can keep up with you and your lifestyle! From a leader in flash memory storage, this card is ideal for offloading 4K UHD video from your action camera, drone, high-performance camera or smartphone.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
  • The world's fastest transfer speeds of up to 275 MB/s
    Clocking in at up to 275 MB/s, the SanDisk Extreme PRO microSDXC UHS-II Card delivers the fastest transfer speeds that you've ever experienced. So offloading content from your card is a snap. And the time you would have spent waiting for files to transfer goes back into your day.
  • 4K UHD and Full HD video capture
    This card's Class 10 and UHS Speed Class 3 (U3) ratings allow you to record smooth Full HD or 4K UHD video. This means your videos can meet the latest high-resolution standards and will look stunning on 4K UHD TV screens and monitors.
  • Durable design for use in extreme environments
    SanDisk Extreme PRO microSDXC UHS-II Cards are shockproof, temperature-proof, waterproof, and X-ray-proof, so you can enjoy your adventures without worrying about the durability of your memory card.
SanDisk Extreme Pro - flash memory card - 128 GB - microSDXC UHS-II
Flash memory card
microSDXC UHS-II Memory Card
Storage Capacity
128 GB
Speed Rating
UHS Class 3 / Class10
Canada
Flash memory card
Storage Capacity
128 GB
Canada
Speed Class
Read Rate
Up to 275 MB/s
Write Rate
Up to 100 MB/s
Shockproof, waterproof, X-ray-proof, temperature-proof
microSDXC card reader (USB)
Limited warranty - lifetime
15 mm
11 mm
Thickness
1 mm
