SanDisk Extreme Pro 32GB Flash Memory Card
Quicklinx: CPTDWS00 Mfr#: SDCFXPS-032GX46
Type: CompactFlash Card
Capacity: 32GB
Hurry, only 3 left in stock!
£39.58 ex VAT
£47.49 inc VAT
However demanding your schedule, however fast your professional-level DSLR or video camera, 32GB SanDisk Extreme PRO CompactFlash Memory Cards can keep up with ease. Their extreme speed (up to 150MB/sec write) lets you use burst mode to take more frames per second, while their support for  VPG-65 (Video Specification Guarantee) means that you will get unrivalled 4K and Full HD video performance. Plus, their large capacity gives you the storage you'll need to capture more RAW+JPEG, Full HD video, 4K and 3D .
  • Extreme speed
    32GB SanDisk Extreme PRO  CompactFlash Memory Cards are made for people who take their photography seriously. With transfer speeds of up to 160MB/sec and industry-leading shot performance of up to 150MB/sec, burst shooting goes to extreme levels and workflow is optimised from start to finish. They are UDMA 7-enabled, making them ideal for handling RAW image files.
  • Extreme video capture
    The cards' Video Performance Guarantee (VPG) ensures data transfer between card and camera for a sustained data recording rate of 65MB/sec . With this level of performance, it's a revolution in how movies and video projects are shot and viewed: you can rely on the kind of smooth and unbroken video stream – even when recording at 4K resolution – that professional video equipment requires, and record flawlessly without skipped frames.
  • Extreme reliability and endurance
    Your 32GB SanDisk Extreme PRO CompactFlash Memory Card will keep working, even under the most arduous conditions. They are sealed with RTV silicone for added protection against shock and vibration, are backed by rigorous tests, and are capable of performing from -25°C to 85°C.
  • Extreme capacity
    When you have a long day's shooting ahead, 32GB SanDisk Extreme PRO  CompactFlash Memory Cards give you plenty of storage space for any unexpected photo opportunities. Even with Full HD video and high resolution images hungry for storage space, there's plenty of headroom, just in case, so you never have to break off shooting.
  • Reassurance with performance
    SanDisk develops and engineers its CompactFlash Memory Cards to maximise reliability, which means you can count on your 32GB SanDisk Extreme PRO CompactFlash Memory Card to store your important memories. They are also backed by a lifetime warranty .
SanDisk Extreme Pro - flash memory card - 32 GB - CompactFlash
Flash memory card
CompactFlash Card
Size (Type)
Type I
Storage Capacity
32 GB
Speed Rating
1000x/1067x
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
RescuePRO (1 year download)
Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
32 GB
Compatibility
Non-specific
Speed Rating
1000x/1067x
Read Rate
Up to 160 MB/s
Write Rate
Up to 150 MB/s
CompactFlash Card
Size (Type)
Type I
Shockproof, temperature-proof, UDMA 7 Mode, Video Performance Guarantee (VPG)-65
Software Included
Limited warranty - lifetime
43 mm
36 mm
3.3 mm
45 g
-25 °C
85 °C
Capacity: 32GB
Brand: Sandisk
Price Range Ex VAT: 0 - 50
