Sandisk Extreme Portable SSD for PS5 2TB
Quicklinx: J4PHWS00 Mfr#: SDSSDE62P-2T00-G25
Capacity: 2TB, 2TB
Interface: USB 3.2 Gen 2
Type: External hard drive
46 In Stock
£132.50 ex VAT
£159.00 inc VAT
Marketing description is not available.
  • Up to 550MB/s read speeds
    With high-performance transfers with up to 550MB/s read speeds, the SanDisk Extreme Portable SSD lets you offload files in a snap.
  • Works with Windows and Mac, USB-C or USB-A
    Designed to work with both Windows and Mac, the SanDisk Extreme Portable SSD is equipped with a USB 3.1 Type-C connector and also includes a USB Type-C to Type-C cable and a Type-C to Type-A adapter, meaning it will work with the PCs and Macs of today, tomorrow and yesterday.
  • Compact, pocket-sized design
    Good things come in small sizes! The SanDisk Extreme Portable SSD delivers high-performance and capacity in a drive that's smaller than a smartphone.
SanDisk Extreme Portable - SSD - 2 TB - USB 3.2 Gen 2
Solid state drive - external (portable)
2 TB
USB 3.2 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.2 Gen2)
Dust-proof, water resistant, drop-resistant
52.55 mm x 100.8 mm x 9.6 mm
69.4 g
5-year warranty
2 TB
USB 3.2 Gen 2
52.55 mm
100.8 mm
9.6 mm
69.4 g
Performance
Interface Transfer Rate
Internal Data Rate
1000 MBps
Expansion & Connectivity
1 x USB 3.2 Gen 2
Windows 10 or later, Apple macOS 13 or later
1 x USB-C cable - external
IP65
Shipping Width
3.3 cm
Shipping Depth
10.7 cm
Shipping Height
12.7 cm
Limited warranty - 5 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
Capacity: 2TB
Capacity: 2TB
Brand: Sandisk
