Get the best shots from your mid-range to high-end DSLR with professional-grade SanDisk Extreme CompactFlash Memory Cards, however punishing your schedule or tough the environment. With up to 120MB/sec read and up to 60MB/sec write speeds, plus Video Performance Guarantee (VPG-20) , the 16GB SanDisk Extreme CompactFlash Memory Card helps you take advantage of your camera's advanced features and improves your workflow functions.
Extreme speed
16GB SanDisk Extreme CompactFlash Memory Cards are made for people who take their photography seriously. With an outstanding combination of shot speeds of up to 60MB/sec and up to 120MB/sec transfer speeds, you can maximise your creative potential.Their UDMA-7 performance also makes them ideal for handling RAW image files. -
Extreme video capture
Featuring a Video Performance Guarantee (VPG) profile specification, the 16GB SanDisk Extreme CompactFlash Memory Card can keep up with the extreme memory demands of professional video equipment. The card's VPG ensures data transfer between card and camera for a sustained data recording rate of 20MB/sec, ensuring a smooth and unbroken video stream. You will be able to record flawlessly in Full HD video (1080p) without skipped frames. -
Extreme reliability and durability
You can be certain that your SanDisk Extreme CompactFlash Memory Card will keep working, even under the most arduous conditions. Sealed with RTV silicone for added protection against shock and vibration, and backed by rigorous tests, they are designed to perform from -25°C to 85°C. -
Extreme capacity
16GB SanDisk Extreme CompactFlash Memory Cards ensure that you have plenty of storage space for a long day's shooting. Even with Full HD video and high resolution images hungry for storage space, there's plenty of headroom, just in case. -
Reassurance with performance
SanDisk develops and engineers its SanDisk Extreme CompactFlash Memory Cards to maximise reliability, so you can count on your 16GB SanDisk Extreme CompactFlash Memory Card to store your important memories.You can shoot with total peace of mind. 16GB SanDisk Extreme CompactFlash Memory Cards are backed by a lifetime limited warranty .
- SanDisk Extreme - flash memory card - 16 GB - CompactFlash
- Product Type
- Flash memory card
- Form Factor
- CompactFlash Card
- Storage Capacity
- 16 GB
- Localisation
- Latin America, Asia Pacific, Middle East, Africa, Europe
- Limited lifetime warranty (Germany and regions not recognizing limited lifetime warranty - 30 years)
- Product Type
- Flash memory card
- Storage Capacity
- 16 GB
- Localisation
- Read Rate
- Up to 120 MB/s
- Write Rate
- Up to 60 MB/s
- Form Factor
- CompactFlash Card
- UDMA 7 Mode
- Limited warranty - lifetime , Germany: limited warranty - 30 years
- 42.7 mm
- 3.56 mm
- 35.81 mm
- 6.35 g
