Your basket is empty
Sandisk Enterprise Optimus 2 Ultra 600GB SSD 2.5" SAS 6Gb/s
Quicklinx: C4S6WS00 Mfr#: SDLKOCGW-600G-5CA1
SanDisk's newest generation of SSDs feature a native SAS 6Gb/s interface, outstanding performance metrics, and a comprehensive set of high-end features making them ideal for a wide variety of enterprise applications such as servers, external storage arrays, and storage area networks (SAN) where performance and high-availability are required, while integrating with existing infrastructure. OEMs and IT managers no longer have to compromise on performance, endurance and reliability to obtain affordability. Optimus SSDs offer all four in a single package through a combination of unique and innovative IP, and the use of Multi-Level Cell (MLC) flash.
SanDisk Optimus Ultra - solid state drive - 600 GB - SAS 6Gb/s
Solid state drive - internal
600 GB
NAND Flash Memory Type
19nm multi-level cell (MLC)
2.5" x 1/8H
SAS 6Gb/s
Data Transfer Rate
600 MBps
FlashGuard Technology, DataGuard Technology, EverGuard Technology, Guardian Technology Platform, built-in backup power circuitry, Flexible Redundant Array of Memory Elements (F.R.A.M.E.)
69.85 mm x 100.2 mm x 9.5 mm
5 years warranty
600 GB
2.5" x 1/8H
SAS 6Gb/s
69.85 mm
100.2 mm
9.5 mm
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 500 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
40000 IOPS
Reliability
MTBF
2,500,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5" x 1/8H
Power Consumption
7 Watt (active)
Limited warranty - 5 years
70 °C
5 - 95% (non-condensing)
Shock Tolerance
1000 g @ 0.5ms
Vibration Tolerance
2.17 g @ 7-800 Hz (operating)
