SanDisk's newest generation of SSDs feature a native SAS 6Gb/s interface, outstanding performance metrics, and a comprehensive set of high-end features making them ideal for a wide variety of enterprise applications such as servers, external storage arrays, and storage area networks (SAN) where performance and high-availability are required, while integrating with existing infrastructure. OEMs and IT managers no longer have to compromise on performance, endurance and reliability to obtain affordability. Optimus SSDs offer all four in a single package through a combination of unique and innovative IP, and the use of Multi-Level Cell (MLC) flash.
- SanDisk Optimus Ultra - SSD - 300 GB - SAS 6Gb/s
- Solid state drive - internal
- Capacity
- 300 GB
- NAND Flash Memory Type
- 19nm multi-level cell (MLC)
- Form Factor
- 2.5" x 1/8H
- Interface
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- FlashGuard Technology, DataGuard Technology, EverGuard Technology, Guardian Technology Platform, built-in backup power circuitry, Flexible Redundant Array of Memory Elements (F.R.A.M.E.)
- 69.85 mm x 100.2 mm x 9.5 mm
- 5-year warranty
- Capacity
- 300 GB
- Form Factor
- 2.5" x 1/8H
- Interface
- SAS 6Gb/s
- 69.85 mm
- 100.2 mm
- 9.5 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps (read) / 500 MBps (write)
- 4KB Random Read
- 95000 IOPS
- 4KB Random Write
- 40000 IOPS
Reliability
- MTBF
- 2,500,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x SAS 6Gb/s
- Compatible Bay
- 2.5" x 1/8H
- Power Consumption
- 7 Watt (active)
- Limited warranty - 5 years
- 0 °C
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance
- 1000 g @ 0.5ms
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating)
