Product
Brand
Sandisk Enterprise Optimus 2 Extreme 400GB SSD 2.5" SAS 6Gb/s
Quicklinx: C4S0WS00 Mfr#: SDLKOC9W-400G-5CA1
Optimus Extreme SAS SSDs are designed for demanding write-intensive application workloads that need the highest levels of performance and reliability. Examples include financial applications and databases associated with workloads that are time-sensitive and produce results that are critical to the businesses they support. Write-intensive workloads include database logging, data warehousing, high-performance computing (HPC) - especially when the HPC workload supports business decisions such as oil and gas applications - and financial on-line transaction processing (OLTP) applications.
SanDisk Optimus Extreme - solid state drive - 400 GB - SAS 6Gb/s
Solid state drive - internal
400 GB
NAND Flash Memory Type
19nm multi-level cell (MLC)
2.5" x 1/8H
SAS 6Gb/s
Data Transfer Rate
600 MBps
FlashGuard Technology, DataGuard Technology, EverGuard Technology, Guardian Technology Platform, built-in backup power circuitry, Flexible Redundant Array of Memory Elements (F.R.A.M.E.)
69.85 mm x 100.2 mm x 9.5 mm
5 years warranty
400 GB
2.5" x 1/8H
SAS 6Gb/s
69.85 mm
100.2 mm
9.5 mm
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 500 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
40000 IOPS
Reliability
MTBF
2,500,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5" x 1/8H
Power Consumption
7 Watt (active)
Limited warranty - 5 years
70 °C
5 - 95% (non-condensing)
Shock Tolerance
1000 g @ 0.5ms
Vibration Tolerance
2.17 g @ 7-800 Hz (operating)
