Optimus Extreme SAS SSDs are designed for demanding write-intensive application workloads that need the highest levels of performance and reliability. Examples include financial applications and databases associated with workloads that are time-sensitive and produce results that are critical to the businesses they support. Write-intensive workloads include database logging, data warehousing, high-performance computing (HPC) - especially when the HPC workload supports business decisions such as oil and gas applications - and financial on-line transaction processing (OLTP) applications.
Database logging
Database logging is a write-intensive workload that allows customers to recover from failures by helping to connect primary and secondary databases. These database logs keep records of all database changes as transactions are updated, and they roll data forward to the point of failure. In cases of unplanned downtime, databases can be restored to a point beyond the last full, offline back-up, because they preserve the last in-flight transactions. -
Databases and data warehouses
Database workloads require fast and accurate writes to disk, as well as easy access to the stored data. SanDisk Optimus Extreme SSDs support database workloads, even in virtualized computing environments. This is important because many IT organizations are consolidating database workloads to run on fewer physical servers, resulting in more efficient infrastructures that host business workloads in less data center space, and require less power and cooling. By hosting more virtual machines (VMs) per physical server, customers reduce total cost of ownership (TCO) and increase return on investment (ROI) for new server deployments that have SSDs, compared with hard-disk (HDD) deployments. -
High-performance computing (HPC)
High-performance computing (HPC) workloads consist of high-volume processing of large datasets which are greatly benefited by using flash technology. HPC includes engineering and data-intensive workloads like seismic analysis, oil and gas exploration, weather forecasting, and market simulations. Flash storage SSDs help each server's application in an HPC cluster to work more effectively and to protect data as it is generated by scale-out applications across the cluster.
- SanDisk Optimus Extreme - SSD - 100 GB - SAS 6Gb/s
- Solid state drive - internal
- Capacity
- 100 GB
- NAND Flash Memory Type
- 19nm multi-level cell (MLC)
- Form Factor
- 2.5" x 1/8H
- Interface
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- FlashGuard Technology, DataGuard Technology, EverGuard Technology, Guardian Technology Platform, built-in backup power circuitry, Flexible Redundant Array of Memory Elements (F.R.A.M.E.)
- 69.85 mm x 100.2 mm x 9.5 mm
- 5-year warranty
- Capacity
- 100 GB
- Form Factor
- 2.5" x 1/8H
- Interface
- SAS 6Gb/s
- 69.85 mm
- 100.2 mm
- 9.5 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps (read) / 500 MBps (write)
- 4KB Random Read
- 95000 IOPS
- 4KB Random Write
- 40000 IOPS
Reliability
- MTBF
- 2,500,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x SAS 6Gb/s
- Compatible Bay
- 2.5" x 1/8H
- Power Consumption
- 7 Watt (active)
- Limited warranty - 5 years
- 0 °C
- 70 °C
- 5 - 95% (non-condensing)
- Shock Tolerance
- 1000 g @ 0.5ms
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating)
