SanDisk Cruzer Switch - USB flash drive - 32 GB
Quicklinx: 8HVSWS00 Mfr#: SDCZ52-032G-B35
The Cruzer Switch USB Flash Drive makes it easier than ever to back up, transport, and share your files. This USB drive keeps your photos, videos, music, and personal data secure with its protective cap and SanDisk's exclusive password-protection software.
Flip-top design with protective cap
32GB Drive can hold your most important data
SanDisk SecureAccess™ software provides password protection
Includes up to 2GB of online backup with YuuWaa™
Keychain loop for easy carrying
Simple Flip-Top Design Protects USB Connector
With its unique flip-top design, the Cruzer Switch USB flash drive is as portable as it is secure. The drive's cap pivots and secures firmly, protecting the USB connector from damage when not in use. The cap has a convenient keychain loop that makes it easy to carry wherever you go.
High-Capacity Drive Stores Your Essential Files
Designed by the company that pioneered the USB flash drive category, the Cruzer Switch USB flash drive packs ample storage space in a compact form. Available in capacities up to 32GB, this flash drive can accommodate photos, songs, and all of your personal data.
Simple, Drag-and-Drop File Loading
Adding photos, music, and other files to the Cruzer Switch USB flash drive is easy: simply plug the drive into your computer's USB port and drag your files into the flash drive's folder. No additional drivers or software are necessary, so you can start storing, transporting, and sharing your data immediately.
SanDisk SecureAccess Software Protects Files from Unauthorized Access
With SanDisk SecureAccess included with each Cruzer Switch USB flash drive, you can create a password-protected private folder on your USB drive. The password protection uses 128-bit AES encryption, so you'll be able to share your USB drive without compromising your private files.
Includes 2GB of Cloud Storage offered by YuuWaa
The Cruzer Switch USB flash drive comes with free access to YuuWaa, a cloud storage service provider. You'll receive 2GB of online storage space. With the user-friendly drag-and-drop interface, it's easy to transfer your important files from your drive to a secure YuuWaa server.
  • The capacity you need to store more
    Even with Full HD video and high resolution images hungry for storage space, 32GB Cruzer Switch USB Flash Drives give you plenty of headroom, just in case, for carrying around all of your favourite videos, photos and music, or large work files.
  • Keep your data physically safe
    Cruzer Switch USB Flash Drives have an eye-catching flip top. You can open and use the USB Flash Drive with the flick of a finger, and because you don't need to take off the cap, you always know where to find it. Plus, you can attach the 32GB Cruzer Switch USB Flash Drive to a lanyard or keyring so you won't lose it or leave it behind.
  • Stay protected with SanDisk
    SanDisk SecureAccess software makes it easy to protect personal or critical files such as business presentations or legal documents. Simply drag and drop files into the vault and they'll be protected by a personal password and automatic 128-bit AES encryption . This means that your content will stay private and secure when you take the drive out and about, or if you store it away for safekeeping.
  • Compatibility
    The 32GB Cruzer Switch USB Flash Drive is optimised for laptops and devices with USB 2.0 ports.
  • Reassurance with performance
    SanDisk develops and engineers its USB Flash Drives to maximise reliability, so you can count on your 32GB Cruzer Switch USB Flash Drive to store your important files. Enjoy yourself or work away with total peace of mind. Cruzer Switch USB Flash Drives are backed by a five-year warranty.
USB flash drive
Interface Type
USB 2.0
Storage Capacity
32 GB
Encryption Algorithm
128-bit AES
Europe
Software Included
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
5-year warranty
USB flash drive
Storage Capacity
32 GB
128-bit AES
Europe
Interface Type
USB 2.0
Encryption support, password protection, LED access indicator
Software Included
Limited warranty - 5 years
20.1 mm
45.2 mm
7.4 mm
3.6 g
