Sandisk Cruzer Fit 64GB USB Flash Drive
Quicklinx: CNK4WS00 Mfr#: SDCZ33-064G-B35
Sleek in style and great in value, the 64GB Cruzer Fit USB Flash Drive is cleverly designed with a low-profile. That means you can slot it neatly into notebooks, tablets, TVs or car audios, even in the tightest spaces, and keep it there without fear of knocking it. Simply, it takes up so little space that it's surprising how much you can store in it: your favourite pictures, music and video collection. Its small footprint also makes it easier to start sharing with your family and friends. Plus, the 64GB Cruzer Fit USB Flash Drive can also keep your private data private, with the included SanDisk SecureAccess software .
  • The capacity you need to store more
    Even when videos and high resolution images are hungry for space, the 64GB Cruzer Fit USB Flash Drive gives you the storage you need in a compact and portable device. There's plenty of headroom, just in case, for carrying around all of your favourite videos, photos and music, or large work files.
  • Small but perfectly formed
    The 64GB Cruzer Fit USB Flash Drive is the smallest in our range at 2 cm long – and at just 1.2 grams with its cap off, it is also incredibly light. Its low profile lets it slot easily into the most restricted or awkward spaces, and makes it less likely that it will get knocked. Fit the USB flash drive comfortably in the palm of your hand, slide it into a pocket or hang it from your keychain.
  • Stay protected with SanDisk
    SanDisk SecureAccess software makes it easy to protect personal or critical files such as business presentations or legal documents. Simply drag and drop files into the vault and they'll be protected by a personal password and automatic 128-bit AES encryption . This means that your content will stay private and secure when you take the drive out and about, or if you store it away for safekeeping.
  • Compatibility
    The 64GB Cruzer Fit Flash Drive is optimised for laptops and devices with USB 2.0 ports.
  • Reassurance with performance
    SanDisk develops and engineers its USB flash drives to maximise reliability, so you can count on your 64GB Cruzer Fit USB Flash Drive to store your important files. Enjoy yourself or work away with total peace of mind. Cruzer Fit USB Flash Drives are backed by a five-year limited warranty.
SanDisk Cruzer Fit - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
64 GB
Encryption Algorithm
128-bit AES
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
SanDisk SecureAccess, YuuWaa Backup
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
5-year warranty
USB flash drive
Storage Capacity
64 GB
128-bit AES
Interface Type
USB 2.0
Encryption support, password protection
Software Included
Limited warranty - 5 years
