Plug In and Leave On for Unobtrusive File Transfer
With its advanced data security options and spacious capacity, the Cruzer Fit USB Flash Drive gives you a secure, easy way to transfer your personal files. This USB drive features a convenient low-profile design that's ideal for situations where a full-size USB drive is just too big, such as use with a TV or car audio device. The Cruzer Fit USB also connects easily to computers and tablets.
Low-profile design for easy USB connectivity
Store all your most important data with 32GB capacity
SanDisk SecureAccess™ software provides password protection
Includes up to 2GB of online backup optionally available from YuuWaa
Fits unobtrusively in a tablet or car audio USB port
Low-Profile Form Factor for Easy Connections
The drive's low-profile design allows it to easily connect to any USB device. Connect it to hard-to-access TV USB ports for HD video play back or bring your entire music library to your car via the USB port on your vehicle's audio system. The flash drive comes with a protective cap, which shields the USB connector from damage when not in use.
High-Capacity Drive Holds Music, Video, Photos, and Personal Files
Despite its compact size, the Cruzer Fit USB flash drive packs enough capacity for your favorite files and your most critical personal data. Available in 32GB, the drive can accommodate photos, songs, and whatever else you need to carry.
Add Files Easily with Drag-and-Drop File Loading
It's easy to add files to the Cruzer Fit USB flash drive: just plug the USB drive into your computer's USB port and drag your files into the drive's folder. You don't need to download drivers or install software to use it, so you can start storing, transporting, and sharing your data immediately.
SanDisk SecureAccessSoftware Protects Your Private Files
The Cruzer Fit USB flash drive comes with SanDisk SecureAccess, which creates a password-protected private folder on your flash drive. With your private files protected with 128-bit AES encryption, you'll be able to share your USB drive without compromising your privacy.
Includes 2GB of Cloud Storage offered by YuuWaa
The Cruzer Fit USB flash drive also comes with the added protection of secure online backup (up to 2 GB optionally available) offered byYuuWaa™, a cloud storage service. Using a user-friendly drag-and-drop interface that syncs with your USB drive, the Cruzer Fit USB flash drive lets you easily transfer files to a secure YuuWaa server for safe online backup.
The capacity you need to store more
Even with Full HD video and high resolution images hungry for storage space, 32GB Cruzer Fit USB Flash Drives give you plenty of headroom, just in case, for carrying around all of your favourite videos, photos and music, or large work files. -
Small but perfectly formed
The 32GB Cruzer Fit USB Flash Drive is the smallest in our range at just over 2 cm long – and at just 1.4 grams with its cap off, it is also incredibly light. Its low profile lets it slot easily into the most restricted or awkward spaces, and makes it less likely that it will get knocked. Fit the USB Flash Drive comfortably in the palm of your hand, slide it into a pocket or hang it from your keychain. -
Stay protected with SanDisk
SanDisk SecureAccess software makes it easy to protect personal or critical files such as business presentations or legal documents. Simply drag and drop files into the vault and they'll be protected by a personal password and automatic 128-bit AES encryption . This means that your content will stay private and secure when you take the drive out and about, or if you store it away for safekeeping. -
Compatibility
The 32GB Cruzer Fit Flash Drive is optimised for laptops and devices with USB 2.0 ports. -
Reassurance with performance
SanDisk develops and engineers its USB Flash Drives to maximise reliability, so you can count on your 32GB Cruzer Fit USB Flash Drive to store your important files. Enjoy yourself or work away with total peace of mind. Cruzer Fit USB Flash Drives are backed by a five-year warranty.
- SanDisk Cruzer Fit - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 32 GB
- Encryption Algorithm
- 128-bit AES
- Software Included
- SanDisk SecureAccess
- OS Required
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- 5 years warranty (regions not recognising "limited" warranty - 5 years)
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- 128-bit AES
- Compatibility
- Non-specific
- Interface Type
- USB 2.0
- Encryption support, password protection
- AES-128
- Software Included
- OS Required
- Limited warranty - 5 years
