SanDisk Cruzer Fit - USB flash drive - 16 GB - USB 2.0
Quicklinx: 89VHWS00 Mfr#: SDCZ33-016G-B35
Whether it's your favorite music or your most important work documents, the Cruzer® Fit™ USB flash drive gives you the storage you need in a compact and portable device.
With its low-profile design, the Cruzer® Fit™ USB flash drive easily fits USB ports and blends in with your notebooks, tablets, TVs and car audio systems. Whether it's your favorite music, pictures, music collection, video collection or your work documents, the Cruzer® Fit™ USB flash drive gives you the ever-present storage you need in a compact and portable device. Protect access to your private data with the included SanDisk® SecureAccess™ software, and get the added protection of secure online backup (up to 2 GB optionally available) offered by YuuWaa™.
When your data matters, you can trust SanDisk®.
Highlights
Low profile
LED to monitor drive's activity
Store, protect and transfer your videos, music, photos, or other files
Password protect and encrypt your private files with SanDisk® SecureAccess™ software
Added protection with secure online backup (up to 2 GB* optionally available) offered by YuuWaa™
  • The capacity you need to store more
    Even with Full HD video and high resolution images hungry for storage space, 16GB Cruzer Fit USB Flash Drives give you plenty of headroom, just in case, for carrying around all of your favourite videos, photos and music, or large work files.
  • Small but perfectly formed
    The 16GB Cruzer Fit USB Flash Drive is the smallest in our range at just over 2 cm long – and at just 1.4 grams with its cap off, it is also incredibly light. Its low profile lets it slot easily into the most restricted or awkward spaces, and makes it less likely that it will get knocked. Fit the USB Flash Drive comfortably in the palm of your hand, slide it into a pocket or hang it from your keychain.
  • Stay protected with SanDisk
    SanDisk SecureAccess software makes it easy to protect personal or critical files such as business presentations or legal documents. Simply drag and drop files into the vault and they'll be protected by a personal password and automatic 128-bit AES encryption . This means that your content will stay private and secure when you take the drive out and about, or if you store it away for safekeeping.
  • Compatibility
    The 16GB Cruzer Fit Flash Drive is optimised for laptops and devices with USB 2.0 ports.
  • Reassurance with performance
    SanDisk develops and engineers its USB Flash Drives to maximise reliability, so you can count on your 16GB Cruzer Fit USB Flash Drive to store your important files. Enjoy yourself or work away with total peace of mind. Cruzer Fit USB Flash Drives are backed by a five-year warranty.
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Encryption Algorithm
128-bit AES
Europe
Software Included
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
5-year warranty
USB flash drive
Storage Capacity
16 GB
128-bit AES
Europe
Interface Type
USB 2.0
Encryption support, password protection, LED access indicator
Software Included
Limited warranty - 5 years
14.7 mm
21.6 mm
6.9 mm
2.5 g
