Product
SanDisk Cruzer Blade - USB flash drive - 32 GB - USB 2.0
Quicklinx: 7X6GWS00 Mfr#: SDCZ50-032G-B35
Capacity: 32GB
Interface: USB 2.0
Hurry, only 2 left in stock!
£6.37 ex VAT
£7.64 inc VAT
Express delivery Order within the next 20 hours for delivery on Monday
With its stylish, compact design and generous capacity, the Cruzer Blade USB Flash Drive makes it easy to back up, transfer, and share your files. At 32GB, this USB drive lets you carry your photos, movies, music, and personal data wherever you go.
  • Compact design fits in your pocket
  • 32GB can hold your most important data
  • SanDisk SecureAccess™ software password protects your files
  • Includes up to 2GB of online backup with YuuWaa™
  • Transports important personal files, music, and video
Compact Design for Maximum Portability
The Cruzer Blade USB flash drive features a compact design that fits easily into a pocket or computer bag. This USB drive has a sleek black and red design that coordinates with many electronic devices.
High-Capacity Drive Accommodates Your Favorite Media Files
Designed by SanDisk, a USB in flash memory innovation, the Cruzer Blade USB flash drive packs generous capacity into a compact form. Available in sizes up to 32GB, this USB drive can hold all your must-have files.
Simple Drag-and-Drop File Backup
Transferring data onto the Cruzer Blade USB flash drive is easy: simply plug it into your computer's USB port and drag files into the drive's folder. After a fast, first time driver download, this USB drive lets you start storing, transporting, and sharing your data immediately.
SanDisk SecureAccess Software Protects Drive from Unauthorized Access
The Cruzer Blade USB flash drive comes with the exclusive SanDisk SecureAccess , which creates a password-protected private folder on your flash drive. SanDisk SecureAccess software uses 128-bit AES encryption, so you'll be able to share the files you want while keeping your private files locked.
Includes 2GB of Cloud Storage Offer from YuuWaa
The Cruzer Blade USB flash drive includes free access to 2GB of online storage offered by YuuWaa, a cloud storage service that syncs with your USB drive. Thanks to a user-friendly drag-and-drop interface, it's easy to transfer files from your drive to a secure YuuWaa server for safe online backup.
Warranty
The Cruzer Blade USB Flash Drive is backed by a two-year limited warranty
  • The capacity you need to store more
    32GB Cruzer Blade USB Flash Drives give you plenty of headroom, just in case. Even with Full HD  video and high resolution images hungry for storage space, you have ample space for storing and sharing the videos, photos and music you love and the work you need to do..
  • Small but perfectly formed
    The 32GB Cruzer Blade USB Flash Drive is one of the smallest in our range at just over 4cm long – and at 2.50g, it is also incredibly light – making it superbly easy to take around with you. Fit the USB Flash Drive comfortably in the palm of your hand, slide it into a pocket or hang it from your keychain..
  • Stay protected with SanDisk
    SanDisk SecureAccess software makes it easy to protect personal or critical files such as business presentations or legal documents. Simply drag and drop files into the vault and they'll be protected by a personal password and automatic 128-bit AES encryption . This means that your content will stay private and secure when you take the drive out and about, or if you store it away for safekeeping..
  • Compatibility
    The Cruzer Blade Flash Drive is optimised for laptops and devices with USB 2.0 ports..
  • Reassurance with performance
    SanDisk develops and engineers its USB Flash Drives to maximise reliability, so you can count on your 32GB Cruzer Blade USB Flash Drive to store your important files.You can enjoy yourself or work away with total peace of mind. 32GB Cruzer Blade USB Flash Drives are backed by a five-year limited warranty..
USB flash drive
Interface Type
USB 2.0
Storage Capacity
32 GB
Enclosure Colour
Red, sleek black
Latin America, Asia Pacific, Middle East, Africa, Europe
Microsoft Certification
Compatible with Windows 7
5 years warranty (United States - 2 years)
USB flash drive
Storage Capacity
32 GB
Enclosure Colour
Red, sleek black
Compatibility
Non-specific
Interface Type
USB 2.0
Limited warranty - 5 years
7.4 mm
17.6 mm
41.5 mm
45 °C
Capacity: 32GB
Interface: USB 2.0
Brand: Sandisk
Price Range Ex VAT: 0 - 50
