Capture, carry and keep more high-quality photos and Full HD video (1080p) on your Android smartphone or tablet with up to 128GB SanDisk Ultra microSDXC UHS-I card in the slot.Transfer pictures and videos from the card to your PC at a rate of up to 80MB/s. The SanDisk Memory Zone app, available on the Google Play store, makes it easy to view, access, and back up your files from your phone's memory . To help your smartphone run at its peak performance, set the app to automatically off-load files from your smartphone's internal memory to the card.Built to perform in extreme conditions, SanDisk Ultra microSDHC and microSDXC cards are water proof, temperature proof, shock proof, X-ray proof and magnet proof. The SanDisk Ultra card is rated Class 10 for Full HD video (1080p) and comes with a SD adapter and a 10-year warranty .
Capture, carry and keep it all
With up to 128GB microSDHC and microSDXC card capacity, SanDisk offers Android device users the freedom to stop worrying about what to keep and what to delete and just keep shooting. -
Class 10 Speed Rating for Full HD Video Captur
This memory card features Class 10 video rating for high-quality video recording, so you can capture Full HD video (1080p) without dropouts and stuttering. And with up to 128GB of storage space, the cards allow you to store plenty of Full HD videos before you have to transfer files to your computer. -
Ultra-fast transfer to your computer
With transfer speeds up to 80MB/s, you won't have to wait for your photos and videos to move to your computer. -
Built to perform in harsh conditions
SanDisk Ultra microSDHC and microSDXC UHS-I Cards are waterproof, shockproof, x-ray proof, temperature proof and magnet proof to protect your memories from life's mishaps. Take your phone or tablet to the snow, the pool, or the desert. Your card will survive, even if your device doesn't.
- SanDisk Ultra - flash memory card - 64 GB - microSDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDXC UHS-I Memory Card
- Storage Capacity
- 64 GB
- Speed Rating
- Class 10
- Included Memory Adapter
- microSDXC to SD adapter
- Software Included
- SanDisk Memory Zone
- Microsoft Certification
- Compatible with Windows 7
- 10 years warranty
- Product Type
- Flash memory card
- Storage Capacity
- 64 GB
- Speed Class
- Class 10
- Read Rate
- Up to 80 MB/s
- Form Factor
- Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof
- Software Included
- Limited warranty - 10 years
- 14.99 mm
- 10.92 mm
- Thickness
- 1.02 mm
- 4.54 g
