Your basket is empty
Sandisk 64GB Ultra microSDXC + SD Adapter 80MB/s (mobile)
Quicklinx: BHC8WS00 Mfr#: SDSQUNC-064G-GN6MA
Capture, carry and keep more high-quality photos and Full HD video (1080p) on your Android smartphone or tablet with up to 128GB SanDisk Ultra microSDXC UHS-I card in the slot.Transfer pictures and videos from the card to your PC at a rate of up to 80MB/s. The SanDisk Memory Zone app, available on the Google Play store, makes it easy to view, access, and back up your files from your phone's memory . To help your smartphone run at its peak performance, set the app to automatically off-load files from your smartphone's internal memory to the card.Built to perform in extreme conditions, SanDisk Ultra microSDHC and microSDXC cards are water proof, temperature proof, shock proof, X-ray proof and magnet proof. The SanDisk Ultra card is rated Class 10 for Full HD video (1080p) and comes with a SD adapter and a 10-year warranty .
SanDisk Ultra - flash memory card - 64 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
Class 10
Included Memory Adapter
microSDXC to SD adapter
Software Included
SanDisk Memory Zone
Microsoft Certification
Compatible with Windows 7
10 years warranty
Flash memory card
Storage Capacity
64 GB
Compatibility
Non-specific
SD Speed Class
Class 10
Read Rate
Up to 80 MB/s
Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof
Software Included
SanDisk Memory Zone
Limited warranty - 10 years
14.99 mm
10.92 mm
Thickness
1.02 mm
4.54 g
