Your basket is empty
Sandisk 64GB Extreme mSDHC with Adapter
Quicklinx: BXW6WS00 Mfr#: SDSQXNE-064G-GN6MA
Take your data storage to the extreme with the Speed Class 3 compatible Class 10 compliant 64GB Extreme UHS-I microSDXC Memory Card from SanDisk. SanDisk has managed to push the limits of data transfer rates and recording ability with this microSD memory card. Speed Class 3 compatibility allows you to shoot photos in continuous burst mode, and record Full HD, and 4K Ultra HD video. Data read speeds of up to 90 MB/s and write speeds of up to 40 MB/s greatly enhances your workflow while the included SD adapter allows the microSD card to be placed into devices supporting SD, SDHC, and SDXC memory cards.
The downloadable RescuePRO software provides an additional layer of data security by assisting in the recovery of accidentally deleted images. SanDisk also offers their own app, SanDisk Memory Zone, designed to simplify the process of managing files on your smartphone. As with most SanDisk memory cards, this microSD card comes waterproof, temperature proof, x-ray proof, and shock proof allowing you to take your card virtually anywhere life takes you.
  • Enhanced data write speed of up to 40 MB/s allow you to catch all the action
  • Data transfer rates of up to 90 MB/s greatly enhances workflow
  • Includes RescuePRO Deluxe data recovery software downloadable offer, for bringing accidentally deleted images back to file
  • Class 10 + UHS Speed Class 3 (U3) for 3D, Full HD, and 4K video
  • UHS Speed Class 3 (U3) rating provides three times the data rate of UHS Speed Class 1 (U1)
  • This microSD memory card comes waterproof, temperature proof, x-ray proof, and shock proof
  • Engineered with Ultra High Speed (UHS-I) bus architecture
  • Includes SD adapter for compatibility with full size SD, SDHC, and SDXC devices
SanDisk Extreme - flash memory card - 64 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
UHS Class 3 / Class10
Included Memory Adapter
microSDXC to SD adapter
Software Included
SanDisk RescuePRO Deluxe
Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
64 GB
Compatibility
Non-specific
SD Speed Class
Read Rate
Up to 90 MB/s
Write Rate
Up to 40 MB/s
Shock-proof, waterproof, X-ray proof, temperature proof
Software Included
Limited warranty - lifetime
14.99 mm
10.92 mm
Thickness
1.02 mm
-25 °C
85 °C
