Product
Sandisk 64GB Extreme Go USB3.1 Drive
Quicklinx: CYPCWS00 Mfr#: SDCZ800-064G-G46
Capacity: 64GB
Interface: USB 3.1
16 in stock
£25.21 ex VAT
£30.25 inc VAT
Standard delivery Delivered within 3-5 working days
With write speeds of up to 150MB/s, the SanDisk Extreme Go USB 3.1 Flash Drive lets you quickly copy and go. Up to 35X faster than standard USB 2.0 drives, so you can transfer a full-length 4K movie to the drive in less than 40 seconds . The design keeps the retractable connector protected when not in use, and the included SanDisk SecureAccess software provides password protection of your private files while leaving the rest of the drive available for sharing.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
  • High-speed performance
    With write speeds of up to 150 MB/s, the SanDisk Extreme Go USB 3.1 Flash Drive is 35x faster than standard USB 2.0 drives so you can transfer a full-length 4K movie in less than 40 seconds or 1000 photos in less than 60 seconds.
  • Retractable design
    The USB connector retracts to keep it safe when you're not using it.
  • USB 3.1 enabled, yet backward-compatible
    The SanDisk Extreme Go USB 3.1 Flash Drive is backward-compatible so you can plug it into any USB 2.0 or 3.0 port.
SanDisk Extreme Go - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.1
Storage Capacity
64 GB
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
USB flash drive
Storage Capacity
64 GB
Compatibility
Non-specific
Read Rate
Up to 200 MB/s
Write Rate
Up to 150 MB/s
Interface Type
USB 3.1
Retractable connector
Software Included
Limited warranty - lifetime
70.87 mm
21.34 mm
11.43 mm
18.14 g
35 °C
Capacity: 64GB
Interface: USB 3.1
Brand: Sandisk
Price Range Ex VAT: 0 - 50
