Sandisk 256GB Ultra Flair USB3.0
Quicklinx: DQ76WS00 Mfr#: SDCZ73-256G-G46
More than 50 In Stock
£24.95 ex VAT
£29.94 inc VAT
The SanDisk Ultra Flair USB 3.0 flash drive moves your files fast. Spend less time waiting to transfer files and enjoy high-speed USB 3.0 performance of up to 150MB/s1. Its durable and sleek metal casing is tough enough to handle knocks with style. And, with password protection, you can rest assured that your private files stay private2. Store your files in style with the SanDisk Ultra Flair USB 3.0 flash drive.
  • Fly through file transfers
    Experience high-speed USB 3.0 performance of up to 150MB/s1 with the SanDisk Ultra Flair USB 3.0 flash drive. Transfer files faster than standard USB 2.0 drives.
  • Stylish and tough
    With a durable metal case, the SanDisk Ultra Flair USB 3.0 flash drive is both sleek and ready to handle unexpected knocks.
  • Password-protect your files
    Share your movies or music, but rest assured that private files can stay private. Easy-to-use password protection lets you limit who sees certain files.
SanDisk Ultra Flair - USB flash drive - 256 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
256 GB
Encryption Algorithm
128-bit AES
Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included
SanDisk RescuePRO Deluxe, SanDisk SecureAccess
Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 10
5-year warranty
USB flash drive
Storage Capacity
256 GB
128-bit AES
Read Rate
Up to 150 MB/s
Interface Type
USB 3.0
Password protection, metal body
Software Included
Limited warranty - 5 years
13.21 mm
42.42 mm
6.6 mm
45 °C
