Boost your PC's performance by up to 28x with an easy and affordable upgrade to SanDisk Ultra II SSD. You'll enjoy no-wait boot up, and shorter application load and data transfer times than your traditional hard drive ever delivered – plus longer battery life and much cooler, quieter computing, too1. No matter how you use your PC, SanDisk's nCache 2.0 technology makes for a better experience, delivering high speed and staying power, even when you're socialising, shopping and watching the football, all at once. Proven shock and vibration resistance means you won't lose your data even if you drop your computer. When you're ready for a better computing experience without buying a new computer, this easy-to-do-yourself upgrade to SanDisk Ultra II SSD will make your old PC behave like a brand-new machine.
Everything you do on your computer - faster
How fast does your data transfer? How fast do your apps load? Could you brush your teeth in the time it takes for your PC to boot up in the morning? For most users, speed is the first thing on the wish list. SanDisk Ultra II SSD literally does every task faster than a typical hard disk drive. What used to take minutes happens in just a few seconds. -
Performance means more than just speed
Speed is important, and SanDisk Ultra II SSD delivers it, but the performance test results measure more than the fastest speed a computer can achieve for a few seconds at a time. Performance means how long you can count on that speed, how consistently your PC responds, how many things you can do at once without stalling out. It means how well your drive withstands the stresses the world hands out. -
Huge storage capacity, built in
You keep lots of tunes, photos and videos on your PC. You use it for socializing, shopping, banking, email and your online classes. You play games - by yourself or with other people. Add a few more dozen handy apps. And then there's work. Amazing how much space those presentations, PDFs, spread sheets and documents take up. With SanDisk Ultra II SSD, you can add enough capacity for everything you do on your computer, and still have room to spare. -
Runs cool and quiet
Hard disk drives were great in their day, but let's face it - they had their downsides. First your laptop would get so hot you couldn't really hold it on your lap. Then the fan would start up and make a lot of noise. Sometimes you blew through your battery in what seemed like the blink of an eye. With a SanDisk Ultra II SSD, all that is history. -
Always know what's going on
With SanDisk SSD Dashboard, you always have visibility into how your drive's performing, what firmware updates are available, and what you can do to maintain peak performance.
- SanDisk Ultra II - solid state drive - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- nCache 2.0 technology
- 69.85 mm x 100.5 mm x 7 mm
- Localisation
- North America
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.5 mm
- 7 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
Reliability
- MTBF
- 1,750,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Localisation
- North America
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g
- Vibration Tolerance (operating)
- 5 g @ 10-2000 Hz
