Your basket is empty
Sandisk 240GB Extreme 500 Portable SSD
Quicklinx: BZ6ZWS00 Mfr#: SDSSDEXT-240G-G25
The SanDisk Extreme 500 portable SSD is less than half the size of your smartphone and delivers up to 4x the speed of an external hard drive .Get to work in seconds, transfer big videos and photo libraries at up to 415MB/s (for 120GB and 240GB) and up to 430MB/s (for 480GB)-a speed that external hard drives can only dream about. Designed for durability and style, this drive is amazingly compact and has no moving parts to break.Solid state technology offers reliable, responsive, high-performance storage for photographers and videographers who capture and carry lots of big media files. When you care about your day's work, it pays to make the SanDisk Extreme 500 your portable storage drive.
SanDisk Extreme 500 Portable - solid state drive - 240 GB - USB 3.0
Solid state drive - external (portable)
240 GB
USB 3.0
Shock resistant, vibration dampening, heat resistant, software encryption, 128-bit AES
7.569 cm x 1.067 cm x 7.569 cm
78.9 g
Australia, New Zealand, Latin America, Asia Pacific, Middle East, Africa, Europe, Americas
3 years warranty
240 GB
USB 3.0
7.569 cm
1.067 cm
7.569 cm
78.9 g
Performance
Internal Data Rate
415 MBps (read) / 340 MBps (write)
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Software Included
SanDisk SecureAccess
Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Windows 8, Windows 8.1
Limited warranty - 3 years
45 °C
