Sandisk 1TB Ultra 3D 2.5" SATA 6Gb/s SSD
Quicklinx: D3M5WS00 Mfr#: SDSSDH3-1T00-G25
£133.33 ex VAT
£159.99 inc VAT
Get accelerated performance for better gaming and pro-level multitasking with graphics-intensive apps. Powered by 3D NAND technology, the SanDisk Ultra 3D SSD delivers enhanced endurance and reliability, blazing sequential read speeds of up to 560MB/s [550MB/s: 250GB ONLY] and sequential write speeds of up to 530MB/s [550MB/s: 250GB ONLY] for no-wait boot-up, shorter application load times, and quicker data transfer . In addition to cooler, quieter computing, the SanDisk Ultra 3D SSD includes proven shock and vibration-resistance to protect your drive. From the company that invented the solid state technology that makes SSDs possible, the SanDisk Ultra 3D SSD catapults your performance to new levels.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
  • Accelerate your PC
    Load and run applications, games, videos, and photos in an instant so you can spend more time doing, and less time waiting.
  • Faster burst speeds
    Performance is optimized by writing everything into the drive's high-speed buffer before transferring it to the flash array. This innovative architecture enables faster burst speeds.
  • Advanced technology for legendary endurance
    Powerful technology enhances drive endurance for even greater reliability and lower power usage for longer notebook battery life.
  • Durable solid state design
    With no moving parts, the SanDisk Ultra 3D SSD is engineered to resist shock and vibration, helping to keep your data safe even if you drop your computer.
SanDisk Ultra 3D - SSD - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
nCache 2.0 technology, 3D NAND Technology
69.95 mm x 100.5 mm x 7 mm
5-year warranty
1 TB
2.5"
SATA 6Gb/s
69.95 mm
100.5 mm
7 mm
Performance
SSD Endurance
400 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 530 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
84000 IOPS
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Limited warranty - 5 years
70 °C
