Sandisk 16GB Ultra microSDHC & SD Adapter 80MB/s UHS-1
Quicklinx: BHC2WS00 Mfr#: SDSQUNC-016G-GN6IA
SanDisk Ultra microSDHC /microSDXC UHS-I Memory Cards have everything you need to take better pictures and great quality videos. The cards' Class 10 speed rating makes them ideal for shooting Full HD (1080p) video and high resolution photos, while outstanding transfer speeds (up to 80MB/sec) make light work of saving images and footage for editing and sharing.With capacities that extend all the way up to a world-leading 128GB, there's also room to store thousands of high resolution photographs and hours of Full HD (1080p) video. With the included adapter this card can be used as a full-size SDHC/SDXC card for compatibility with your camera, camcorder, laptop, tablet and other devices that support the SDHC/SDXC standard.
  • The capacity you need to capture more images
    Digital cameras and camcorders can take great high resolutionmages and Full HD (1080p) videos. Without enough storage, capturing them all can be a problem. With capacities of up to 128GB – the world's largest capacity microSDXC card – SanDisk Ultra microSDHC/microSDXC UHS-I Memory Cards give you plenty of headroom, just in case, for you to capture the moment with great videos and photos.
  • Make more of speed
    SanDisk Ultra microSDHC/microSDXC UHS-I Memory Cards achieve Class 10 performance ratings, for Full HD (1080p) video recording. They also deliver the write speeds you need to capture better pictures. Transfer speeds of up to 80MB/sec mean it takes less timeor you to transfer files to your PC, while Ultra High Speed (UHS-I) technology allows you to take advantage of burst mode photography.
  • Compatibility
    SanDisk Ultra microSDHC/microSDXC UHS-I Memory Cards work with any microSDXC supporting host device, and include an adapter for compatibility with all full size SDHC/SDXC devices. The adapter also makes it easy for you to transfer photos and videos to your PC.
  • Reassurance with performance
    Wherever you plan to shoot, SanDisk Ultra microSDHC/microSDXC UHS-I Memory Cards will stand up to the conditions. They are water proof, temperature proof, shock proof and X-ray proof, and will even pass through airport scanners unharmed .SanDisk Ultra microSDHC/microSDXC UHS-I Memory Cards are backed by a 10-year warranty .
SanDisk Ultra - flash memory card - 16 GB - microSDHC UHS-I
Flash memory card
microSDHC UHS-I Memory Card
Storage Capacity
16 GB
Speed Rating
Class 10
Included Memory Adapter
microSDHC to SD adapter
Microsoft Certification
Compatible with Windows 7
10 years warranty
Flash memory card
Storage Capacity
16 GB
Speed Class
Class 10
Read Rate
Up to 80 MB/s
Shockproof, magnetic-proof, waterproof, write protection switch, X-ray-proof, temperature-proof
Limited warranty - 10 years
14.99 mm
10.92 mm
Thickness
1.02 mm
4.54 g
