The SanDisk Extreme PRO SDXC UHS-II 16GB card brings you the high performance that today's professional photographers and videographers need to take outstanding shots with high-speed burst mode and capture cinema-quality 4K and Full HD videos . With faster transfer speeds, it also helps you improve post-production workflow efficiency to give you better all-round results. The world's fastest SDXC card, the 16GB SanDisk Extreme PRO SDXC UHS-II card delivers up to 250MB/s write speed. With that speed, you can take remarkable continuous burst-mode shots with your DSLR to make sure that you capture the one you want. Once you've taken your photos, extreme transfer speeds of up to 280MB/s ensure that your workflow becomes even more efficient. The SanDisk Extreme PRO SDXC UHS-II 16GB card also helps you capture high-quality video: it meets the new U3 video capture specification with a minimum sustained video capture rate of 30MB/s for cinema quality 4K, 3D and Full HD video recording . Best results come when used in conjunction with the SanDisk Extreme PRO SD UHS-II Card Reader/Writer (available separately).
The capacity you need to store more
Devices today are expected to do more and store more. 16GB SanDisk Extreme PRO SDXC UHS-II memory cards give you ample room for both planned and spontaneous high-quality shots and videos. -
Make more of speed
SanDisk Extreme PRO SDXC UHS-II 16GB memory cards are the world's fastest SDXC cards, with extreme read speeds of up to 280MB/s and write speeds of 250MB/s so that you benefit from better shot to shot performance. For professional video recording, U3 sustained video capture at 30MB/s delivers cinema-quality 4K, 3D and Full HD . -
Performance anywhere
Water proof, temperature-proof, shock-proof and x-ray-proof, SanDisk Extreme PRO SDXC UHS-II 16GB memory cards are designed to be used almost anywhere. They will even pass through airport scanners unharmed. -
Reassurance with performance
You can shoot with total peace of mind. SanDisk Extreme PRO SDXC UHS-II 16GB memory cards are backed by a lifetime limited warranty . -
Add extra efficiency
Pair SanDisk Extreme PRO SDXC UHS-II 16GB memory cards with the sleek, compact SanDisk Extreme PRO SD UHS-II card reader/writer for an excellent way to increase performance and workflow efficiency. Just 2.25 inches (57.15mm) long, the reader/writer (available separately) supports USB 3.0 interface transfer speeds of up to 500MB/s , allowing you to download high resolution photos and videos onto your desktop or laptop up to 10 times faster than a USB 2.0 interface can support.
- SanDisk Extreme Pro - flash memory card - 16 GB - SDHC UHS-II
- Product Type
- Flash memory card
- Form Factor
- SDHC UHS-II Memory Card
- Storage Capacity
- 16 GB
- Speed Rating
- UHS Class 3 - 1667x/1867x
- Software Included
- RescuePRO Deluxe (1 year download)
- Product Type
- Flash memory card
- Storage Capacity
- 16 GB
- Speed Rating
- 1667x/1867x
- Speed Class
- UHS Class 3
- Read Rate
- Up to 280 MB/s
- Write Rate
- Up to 250 MB/s
- Form Factor
- Shockproof, waterproof, X-ray-proof
- Software Included
- -25 °C
- 85 °C
