Sandisk 16GB Extreme PLUS microSDHC + SD Apapter 95MB/s UHS-1 Card
Quicklinx: BHCCWS00 Mfr#: SDSQXSG-016G-GN6MA
Capture more fast action and record more Full HD or 4K Ultra HD-ready video with your Android smartphone or MIL camera.SanDisk Extreme PLUS cards are built tough for extreme durability, even under challenging environmental conditions .Fast speeds reduce the time you're on hold while your pictures and videos move to your card or from your card to your computer. Storage capacities from 16GB to 64GB expand device memory and leave room to record video that's ready for the new 4K Ultra HD television screens and monitors.
  • The Speeds You Need
    The best stuff happens fast. With a UHS Speed Class 3 rating and extreme speeds up to 95MB/, SanDisk memory cards give you the speed you need to capture every detail. Fast write speeds reduce the time you're on hold while you move pictures and videos to your card. Offload big files faster so you're always ready to catch the next great shot, and enjoy smooth video playback.
  • Catch the Thrill in 4K Ultra HD Detail
    When your memory card is 4K Ultra HD-ready with UHS Speed Class 3 rating , the video you capture is more than moving pictures. With 4K Ultra HD resolution you won't just watch the video, you'll relive the experience. Make sure the videos you shoot today are ready for the new 4K Ultra HD television screens and monitors.
  • Built for Extreme Conditions
    Durability-tested to protect your memories from life's mishaps-waterproof, shock-proof, x-ray proof, temperature proof. Take your phone, tablet, or camera to the mountains, the ocean, or the desert. Even if your device doesn't survive, your SanDisk memory card will.
  • SD Adapter for Versatility
    This card comes with a convenient SD card adapter, so you can also capture and access data on the card with any device that has an SD card slot. You'll be able to use your memory card with SD enabled cameras, camcorders, tablets, and laptops.
SanDisk Extreme PLUS - flash memory card - 16 GB - microSDHC UHS-I
Flash memory card
microSDHC UHS-I Memory Card
Storage Capacity
16 GB
Speed Rating
UHS Class 3 / Class10 - 633x
Latin America, Asia Pacific, Middle East, Africa, Europe
Included Memory Adapter
microSDHC to SD adapter
Software Included
SanDisk RescuePRO Deluxe, SanDisk Memory Zone
Limited lifetime warranty (Germany and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
16 GB
Speed Rating
633x
Speed Class
Read Rate
Up to 95 MB/s
Write Rate
Up to 90 MB/s
Shockproof, waterproof, X-ray-proof, temperature-proof
Software Included
Limited warranty - lifetime , Germany: limited warranty - 30 years
14.99 mm
10.92 mm
Thickness
1.02 mm
4.54 g
