Capture more fast action and record more Full HD or 4K Ultra HD-ready video with your Android smartphone or MIL camera.SanDisk Extreme PLUS cards are built tough for extreme durability, even under challenging environmental conditions .Fast speeds reduce the time you're on hold while your pictures and videos move to your card or from your card to your computer. Storage capacities from 16GB to 64GB expand device memory and leave room to record video that's ready for the new 4K Ultra HD television screens and monitors.
The Speeds You Need
The best stuff happens fast. With a UHS Speed Class 3 rating and extreme speeds up to 95MB/, SanDisk memory cards give you the speed you need to capture every detail. Fast write speeds reduce the time you're on hold while you move pictures and videos to your card. Offload big files faster so you're always ready to catch the next great shot, and enjoy smooth video playback. -
Catch the Thrill in 4K Ultra HD Detail
When your memory card is 4K Ultra HD-ready with UHS Speed Class 3 rating , the video you capture is more than moving pictures. With 4K Ultra HD resolution you won't just watch the video, you'll relive the experience. Make sure the videos you shoot today are ready for the new 4K Ultra HD television screens and monitors. -
Built for Extreme Conditions
Durability-tested to protect your memories from life's mishaps-waterproof, shock-proof, x-ray proof, temperature proof. Take your phone, tablet, or camera to the mountains, the ocean, or the desert. Even if your device doesn't survive, your SanDisk memory card will. -
SD Adapter for Versatility
This card comes with a convenient SD card adapter, so you can also capture and access data on the card with any device that has an SD card slot. You'll be able to use your memory card with SD enabled cameras, camcorders, tablets, and laptops.
- SanDisk Extreme PLUS - flash memory card - 16 GB - microSDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-I Memory Card
- Storage Capacity
- 16 GB
- Speed Rating
- UHS Class 3 / Class10 - 633x
- Localisation
- Latin America, Asia Pacific, Middle East, Africa, Europe
- Included Memory Adapter
- microSDHC to SD adapter
- Software Included
- SanDisk RescuePRO Deluxe, SanDisk Memory Zone
- Limited lifetime warranty (Germany and regions not recognizing limited lifetime warranty - 30 years)
- Product Type
- Flash memory card
- Storage Capacity
- 16 GB
- Localisation
- Speed Rating
- 633x
- Speed Class
- Read Rate
- Up to 95 MB/s
- Write Rate
- Up to 90 MB/s
- Form Factor
- Shockproof, waterproof, X-ray-proof, temperature-proof
- Software Included
- Limited warranty - lifetime , Germany: limited warranty - 30 years
- 14.99 mm
- 10.92 mm
- Thickness
- 1.02 mm
- 4.54 g
