Your basket is empty
Sandisk 16GB Extreme PLUS microSDHC + SD Apapter 95MB/s UHS-1 Card
Quicklinx: BHCCWS00 Mfr#: SDSQXSG-016G-GN6MA
Capture more fast action and record more Full HD or 4K Ultra HD-ready video with your Android smartphone or MIL camera.SanDisk Extreme PLUS cards are built tough for extreme durability, even under challenging environmental conditions .Fast speeds reduce the time you're on hold while your pictures and videos move to your card or from your card to your computer. Storage capacities from 16GB to 64GB expand device memory and leave room to record video that's ready for the new 4K Ultra HD television screens and monitors.
SanDisk Extreme PLUS - flash memory card - 16 GB - microSDHC UHS-I
Flash memory card
microSDHC UHS-I Memory Card
Storage Capacity
16 GB
Speed Rating
UHS Class 3 / Class10 - 633x
Latin America, Asia Pacific, Middle East, Africa, Europe
Included Memory Adapter
microSDHC to SD adapter
Software Included
SanDisk RescuePRO Deluxe, SanDisk Memory Zone
Limited lifetime warranty (Germany and regions not recognizing limited lifetime warranty - 30 years)
Flash memory card
Storage Capacity
16 GB
Compatibility
Non-specific
Speed Rating
633x
SD Speed Class
Read Rate
Up to 95 MB/s
Write Rate
Up to 90 MB/s
Shockproof, waterproof, X-ray-proof, temperature-proof
Software Included
Limited warranty - lifetime
14.99 mm
10.92 mm
Thickness
1.02 mm
4.54 g
