Capture, carry and keep more high-quality photos and Full HD video (1080p) on your Android smartphone or tablet with up to 128GB SanDisk Ultra microSDXC UHS-I card in the slot.Transfer pictures and videos from the card to your PC at a rate of up to 80MB/s. The SanDisk Memory Zone app, available on the Google Play store, makes it easy to view, access, and back up your files from your phone's memory . To help your smartphone run at its peak performance, set the app to automatically off-load files from your smartphone's internal memory to the card.Built to perform in extreme conditions, SanDisk Ultra microSDHC and microSDXC cards are water proof, temperature proof, shock proof, X-ray proof and magnet proof. The SanDisk Ultra card is rated Class 10 for Full HD video (1080p) and comes with a SD adapter and a 10-year warranty .
- SanDisk Ultra - flash memory card - 128 GB - microSDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDXC UHS-I Memory Card
- Storage Capacity
- 128 GB
- Speed Rating
- Class 10
- Localisation
- Latin America, Asia Pacific, Middle East, Africa, Europe
- Included Memory Adapter
- microSDXC to SD adapter
- Microsoft Certification
- Compatible with Windows 7
- 10 years warranty
- Product Type
- Flash memory card
- Storage Capacity
- 128 GB
- Compatibility
- Non-specific
- Localisation
- SD Speed Class
- Class 10
- Read Rate
- Up to 80 MB/s
- Form Factor
- Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof
- Limited warranty - 10 years
- 14.99 mm
- 10.92 mm
- Thickness
- 1.02 mm
- 4.54 g
