With write speeds of up to 150MB/s, the SanDisk Extreme Go USB 3.1 Flash Drive lets you quickly copy and go. Up to 35X faster than standard USB 2.0 drives, so you can transfer a full-length 4K movie to the drive in less than 40 seconds . The design keeps the retractable connector protected when not in use, and the included SanDisk SecureAccess software provides password protection of your private files while leaving the rest of the drive available for sharing.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
High-speed performance
With write speeds of up to 150 MB/s, the SanDisk Extreme Go USB 3.1 Flash Drive is 35x faster than standard USB 2.0 drives so you can transfer a full-length 4K movie in less than 40 seconds or 1000 photos in less than 60 seconds. -
Retractable design
The USB connector retracts to keep it safe when you're not using it. -
USB 3.1 enabled, yet backward-compatible
The SanDisk Extreme Go USB 3.1 Flash Drive is backward-compatible so you can plug it into any USB 2.0 or 3.0 port.
- SanDisk Extreme Go - USB flash drive - 128 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1
- Storage Capacity
- 128 GB
- Localisation
- Latin America, Asia Pacific, Middle East, Africa, Europe
- Software Included
- SanDisk SecureAccess
- Product Type
- USB flash drive
- Storage Capacity
- 128 GB
- Localisation
- Read Rate
- Up to 200 MB/s
- Write Rate
- Up to 150 MB/s
- Interface Type
- USB 3.1
- Retractable connector
- Software Included
- 70.87 mm
- 21.34 mm
- 11.43 mm
- 18.14 g
- 0 °C
- 35 °C
