Ideal for use with mid-range to high-end DSLR cameras and HD camcorders, the SanDisk Extreme CompactFlash Memory Card delivers first-rate read/write speeds to catch fast action shots and enable quick file transfers. This memory card features Video Performance Guarantee (VPG-20) to deliver a minimum sustained recording data rate of 20MB/s to support high-quality Full HD video (1080p) recording. Take advantage of burst-mode photography with the card's write speeds of up to 85MB/s 32-128GB only (567X) and enjoy efficient workflow with its transfer speeds up to 120MB/s (16GB - 128GB cards only). This memory card provides plenty of storage for Full HD videos and RAW photos.
Up to 85MB/s 32-128GB only write speeds for exceptional shot to shot performance
With write speeds of up to 85MB/s 32-128GB only, the SanDisk Extreme CompactFlash Memory Card adds to your mid-range to-high-range DSLR's performance during burst-mode shooting, rapid shots, and RAW plus JPEG capture. The card records photos almost instantly, ensuring you will catch your best shot. -
Includes VPG-20 specification for professional-grade video capture
Featuring a Video Performance Guarantee (VPG-20) profile specification, the SanDisk Extreme CompactFlash memory card can keep up with the steep memory demands of professional video equipment such as HD camcorders. The card's VPG-20 ensures data transfer between card and camera with a sustained data recording rate of 20MB/s for a smooth and unbroken video stream. You'll be able to record in resolutions as high as 1080p without skipped frames. -
Durable design
SanDisk Extreme CompactFlash Memory Cards are designed to handle whatever life throws at you. This card is backed by rigorous stress, shock, and vibration testing and includes RTV silicone coating for protection against shock and vibration. It operates in nearly any climate, with a functioning temperature range of -13 to 185 degrees Fahrenheit. -
High storage capacity
The SanDisk Extreme CompactFlash memory card offers plenty of space to store high-resolution photos and Full HD videos.
- SanDisk Extreme - flash memory card - 128 GB - CompactFlash
- Product Type
- Flash memory card
- Form Factor
- CompactFlash Card
- Storage Capacity
- 128 GB
- Speed Rating
- 567x
- Limited lifetime warranty (Germany,Canada and regions not recognizing limited lifetime warranty - 30 years)
- Product Type
- Flash memory card
- Storage Capacity
- 128 GB
- Speed Rating
- 567x
- Read Rate
- Up to 120 MB/s
- Write Rate
- Up to 85 MB/s
- Form Factor
- CompactFlash Card
- UDMA 7 Mode, Video Performance Guarantee (VPG)-20
- Limited warranty - lifetime , Germany: limited warranty - 30 years , Canada: limited warranty - 30 years
- -25 °C
- 85 °C
